Re: Are RV motors any good?
[Re: dssaa]
#290816
04/17/09 08:02 AM
04/17/09 08:02 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
Why would the tranny not work? I have a 727 sitting that came with the Charger I could probably use..but how is the RV trans different?
Depending on the motorhome, it might have a parking brake on the tailhousing. Aside from that, every one I've ever seen was a short tailshaft.
Search this site, there are quite a few threads on motorhome stuff. This question comes up every few months...
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: dssaa]
#290819
04/17/09 09:04 AM
04/17/09 09:04 AM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
Is it a big block trans , if not it won't fit BUT you could mix and match parts from the motorhome trans to make the motorhome trans a car trans , just be careful with the front planet choice .
[Re: BeEtLeJuIcE !]
#290820
04/17/09 10:05 AM
04/17/09 10:05 AM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
The parking-brake-drum on the tail-shaft was mainly on the up-to-1972 chassis. The plain shorty(not THAT short) ...was from 73 and up.
In any case .. the RV trans is a good piece - Premium parts used in there.
My tranny came out of a 76 Winnibago with the drum on the end. Since the tranny was shot and needed rebuilt anyway, I just had the builder use a standard output shaft and tailhousing to fit going in my truck. My next door neighbor is scrapping a 79 MH with a 440. I could check, but I'm willing to bet it has a drum on the end of it as well. BTW, this 440/727 is for sale if anyone is interested.
[Re: dodgeram440]
#290821
04/17/09 10:17 AM
04/17/09 10:17 AM
Posts: 5,162 CT
GTX MATT
CT
Buy it and put an HP resto cam in it, you'll be happy with it for sure if you dont plan on running a big cam.
The only possible difference to it vs a passenger car 440 from the same year is the possibility of those weird water jacket heads, I think the casting number ends with 213. Theyve got some sort of revised cooling passages. Not sure if they came on 440s your year, but I believe some had them.
