Other ways to break in a cam ? 🤪 #2906994
04/05/21 08:01 PM
04/05/21 08:01 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Are there other ways to break in a cam other than firing up a new engine? I was think about using an old empty block with heads. Not sure what id use to rotate the cam and oil system. Any ideas?
Stand behind your word
Re: Other ways to break in a cam ? 🤪 [Re: Dodge] #2906997
04/05/21 08:22 PM
04/05/21 08:22 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Re: Other ways to break in a cam ? 🤪 [Re: Neil] #2906999
04/05/21 08:29 PM
04/05/21 08:29 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Thanks 😁
Re: Other ways to break in a cam ? 🤪 [Re: Neil] #2907010
04/05/21 08:51 PM
04/05/21 08:51 PM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Am I missing how they are checking to see if the lifters are actually rotating before they run it for a full 30 mins like that?
Re: Other ways to break in a cam ? 🤪 [Re: Alchemi] #2907012
04/05/21 08:57 PM
04/05/21 08:57 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
lifter rotation is everything... if i was worried about cam break in i would use low ratio rockers and break in valve springs.. all the while looking for rotation.
Re: Other ways to break in a cam ? 🤪 [Re: ek3] #2907149
04/06/21 08:32 AM
04/06/21 08:32 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
in my opinion if someone is concerned about flat tappet cam break-in then don't use a fast rate cam; simple. the faster the ramps the more spring that is needed to control the valve train. more spring/ramp speed means a greater chance of scuffing. i seriously doubt that the old factory engines did a break-in procedure, but they never used the ramp speed that is used today. if fast ramp speed and high lift are a must then use a cam that requires a tappet with a wheel on it.
Re: Other ways to break in a cam ? 🤪 [Re: Dodge] #2907269
04/06/21 12:36 PM
04/06/21 12:36 PM
I had one 340 motor years ago that would eat the #5 exhaust lifter after 20,000 shock
It did that twice before we figured out that the block lifter bore was NOT machined correctly puke That customer and friend ended selling the car after the second failure with out fixing the block down
My message is to always break the cam in the block your going to use it in and be very careful about reusing a cam and lifters in another block twocents work
I don't have a accurate number on the total motors I've rebuilt and blue printed but well over 200,I have had three or four of those blocks machine for and fitted with lifter bushings shruggy
Re: Other ways to break in a cam ? 🤪 [Re: Cab_Burge] #2907326
04/06/21 02:24 PM
04/06/21 02:24 PM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Hey Cab, it'd be nice not to have to run the car for 1/2 an hour in my neighborhood. Plus change springs. My 70 chargers kinda loud. The last cam break in was my GTX. Its pretty quiet. Split in 3, 10min run times.
Re: Other ways to break in a cam ? 🤪 [Re: Dodge] #2907362
04/06/21 03:57 PM
04/06/21 03:57 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
WHO ELSE has cut the top of the valve covers off and USED THOSE in the initial fire up of the motor ?
The VIEWED DOWN to see if the lifters are properly rotating!
Re: Other ways to break in a cam ? 🤪 [Re: dOoC] #2907390
04/06/21 06:05 PM
04/06/21 06:05 PM
You can assemble the short block with the cam. lifters and timing set in it and then spin the motor over by hand, after marking the lifters and block, to check if the lifter will rotate after 15 to 30 rotations of the crank, 7 to 15 cam revolutions scope
They should rotate some if they are not tight in the lifters bores scope wrench up
Re: Other ways to break in a cam ? 🤪 [Re: Cab_Burge] #2907445
04/06/21 08:34 PM
04/06/21 08:34 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree
Re: Other ways to break in a cam ? 🤪 [Re: TJP] #2907456
04/06/21 08:50 PM
04/06/21 08:50 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
If you rotate the fresh motor by hand, or whatever, to check lifter rotation,
didn't you just wipe off all the cam lube for when the motor fires ?
Re: Other ways to break in a cam ? 🤪 [Re: hemienvy] #2907466
04/06/21 09:01 PM
04/06/21 09:01 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Seems similar to a new and improved set of ignition points. If I was to invest in anything, it would be a roller lifter.
Re: Other ways to break in a cam ? 🤪 [Re: hemienvy] #2907481
04/06/21 09:27 PM
04/06/21 09:27 PM
Not that I have seen so far shruggy You need to remember that the flat tappet lifters are design to spin on their edges of the cam lobes on the tapered lobe face to prevent them going flat from rubbing all the way across the lobes scope
Re: Other ways to break in a cam ? 🤪 [Re: Cab_Burge] #2907558
04/07/21 02:20 AM
04/07/21 02:20 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I check fitment of the lifters by slipping them in their bores and seeing if I can spin them by hand.
Re: Other ways to break in a cam ? 🤪 [Re: Dodge] #2907573
04/07/21 06:33 AM
04/07/21 06:33 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Im recently out of the mopar musclecar hobby. But my 360 build was gonna use a hyd roller cam/conversion. This is a SIGNIFICANTLY more $$$ option but many legit guys on this forum and in the hobby with all brands and makes have abandoned hyd flat tappet cams due to the modern version of them not having the quality of the past. I remember around 1999 here on moparts the new hyd flat tappet cam destroyed posts starting to appear. Back then it was blamed on the reduced zinc in our favorite brands of oil. But as time went on things like lack of lifter crown, soft metal -basically poor quality has been established.
Keep old mopars alive.
