Re: Any love for the/6?
[Re: Jim_Lusk]
#2907248
04/06/21 12:10 PM
04/06/21 12:10 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Uncle Tonys Garage has videos of slant 6 builds. At 225ci a supercharger from the 231ci 3.8 liter Buick (Bonnevilles Grand Prixs and Lesabres) would be a nice sized component.
Keep old mopars alive.
[Re: 2boltmain]
#2907376
04/06/21 05:02 PM
04/06/21 05:02 PM
Posts: 1,756 London, England
Gavin
London, England
Uncle Tonys Garage has videos of slant 6 builds. At 225ci a supercharger from the 231ci 3.8 liter Buick (Bonnevilles Grand Prixs and Lesabres) would be a nice sized component. He's also a particular fan of the 170 - "the perfect engine". Apparently in its day it ran in some junior NASCAR type series and ran away with the championship against the opposition (presumably other sixes??)
[Re: Gavin]
#2907392
04/06/21 06:25 PM
04/06/21 06:25 PM
Posts: 3,076 Michigan
A727Tflite
Uncle Tonys Garage has videos of slant 6 builds. At 225ci a supercharger from the 231ci 3.8 liter Buick (Bonnevilles Grand Prixs and Lesabres) would be a nice sized component. He's also a particular fan of the 170 - "the perfect engine". Apparently in its day it ran in some junior NASCAR type series and ran away with the championship against the opposition (presumably other sixes??) The slant six was so successful in the NASCAR series that they discontinued the events. They took 1st through 3rd and no one was close. They kicked a$$ on the road course too. But this was a six cylinder event.
[Re: Gavin]
#2907428
04/06/21 07:54 PM
04/06/21 07:54 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
Uncle Tonys Garage has videos of slant 6 builds. At 225ci a supercharger from the 231ci 3.8 liter Buick (Bonnevilles Grand Prixs and Lesabres) would be a nice sized component. He's also a particular fan of the 170 - "the perfect engine". Apparently in its day it ran in some junior NASCAR type series and ran away with the championship against the opposition (presumably other sixes??) That Miata he's stuffing it into is going to be hilarious. Would love to see a reactions video of faces at a Miata event with the hood up.
[Re: 2boltmain]
#2907467
04/06/21 09:02 PM
04/06/21 09:02 PM
Posts: 2,233 ILLINOIS
volaredon
ILLINOIS
Why didnt mopar follow GM and Ford and produce a 300 cubic inch inline 6 cyl?? GM came close they had a 292 CID version. and I havent seen em all but I'm familiar with Uncle Tony.
[Re: volaredon]
#2907788
04/07/21 05:43 PM
04/07/21 05:43 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
What gets me is that everyone who isn't trying to talk me into dumping the/6for a V8 is telling me to dump the 727. It stays for now. Are you wanting suggestions or not? That low 1st and 2nd geared 904 will feel like another 75 HP in that truck and get better MPG. Also a rough truck with a running 318 can typically be had for $500 ish around here and provide every part needed for a swap for less than you just spent on a 225.
[Re: volaredon]
#2907802
04/07/21 06:39 PM
04/07/21 06:39 PM
A727Tflite
What gets me is that everyone who isn't trying to talk me into dumping the/6for a V8 is telling me to dump the 727. It stays for now. With your current 727 and 3.21 you have a starting line ratio of 7.86 in 1st gear. With the 3.21 axle and the low gearset 904 you have an equivalent starting line ratio equal to 3.62 axle ratio behind the 727. But why porting, cutting the head for more power, etc. then leaving something on the table. 1980 and later low gearset transmissions are a dime a dozen plus you can get lockup for better mileage. Only setback is you will need a little longer prop shaft. Obviously your call.
[Re: volaredon]
#2907896
04/08/21 12:12 AM
04/08/21 12:12 AM
Posts: 3,310 Walnut Creek, CA
blown340
Walnut Creek, CA
I race a slant 6 powered 63 valiant in the 24 hours of lemons series and it works really well. This is probably the wrong forum though for slant six info. Check out slantsix.org for good info and look into Dutra's book. https://www.amazon.com/Chrysler-Slant-Six-Engines-Rebuild/dp/1613254326 The people at slantsix.org are really helpful!
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
[Re: volaredon]
#2926043
05/24/21 07:03 AM
05/24/21 07:03 AM
Guitar Jones
Slants are cool because they are unique. You find a few off the beaten path engines in the comp classes. A couple centuries ago a guy named JP Keck (?) ran a 300 cube Ford six in one of the gas classes. He cut up 3 Ford Cleveland heads and welded them together to make one head, put it all in what looked like a Pro Stock Pinto and the thing flew. Unique builds like that are very cool. Today builders seem to have lost that kind of vision and just LS swap everything, BORING! Good for you for sticking with the slant, have you considered cutting up some small block Eddy heads for it? Turbo charging it?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: moparx]
#2927058
05/26/21 07:20 PM
05/26/21 07:20 PM
Posts: 15,867 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
many, many years ago, a buddy of mine from jamestown ny. had a T-bucket that was /6 powered. pretty snappy combo that was, and lots of looks with headers out over the driver's side frame rails ! That's really cool! My first job other than mowing lawns for myself was at a Marina. I was the kid that did anything and everything. As the boss was showing me around we walked by the travel lift and the first thing I noticed was this HUGE thing had a slant six! It was an oldie. For those of you who don't know what a travel lift is here's a picture of a newer one but same design.
Facts are stubborn things.
[Re: larrymopar360]
#2927459
05/27/21 10:13 PM
05/27/21 10:13 PM
Posts: 16,819 Between Houston & Galveston TX
SattyNoCar
I've owned 5 slantys of various years. Every single one of them left me stranded. Two of them, neither myself or an actual mechanic could figure out what the heck was wrong with them (both were in PU's). In disgust, one truck ended up with a sledgehammer thru the windshield then sent to the crusher. The other was sold off for pennies on the dollar because emission laws at the time would have made a V8 swap too much.
I'm not gonna bash on someone if they can make it work, but, I'll never own another (unless I was doing a V8 swap).
John
