440 Crate Drag Engine Options #2907128
04/06/21 06:27 AM
04/06/21 06:27 AM
MASSACHUSETTS
Chip Offline OP
Chip  Offline OP
MASSACHUSETTS
Sent my engine in this winter for a freshen up...3-months later shop finally took it apart and the heads are no good. The Indy 440-1 heads were previously epoxied inside where they were ported to much. So with that...it will be alot of $$$ to put back together with only the crank and rods as usable for a complete new build in my 50-year old 60 over block.
So, I'm thinking go buy a new engine built with the Callies block. Something around 700-800hp dyno tested/broke in, carb to pan for my 1970 Barracuda door car. I see Indy and Caroline Machine Engines has options.
Who else has crate engines? How much weight does a Callies block add?
Thanks, Chip
Re: 440 Crate Drag Engine Options [Re: Chip] #2907221
04/06/21 11:30 AM
04/06/21 11:30 AM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
I would call Best Machine and discuss all your needs.
Re: 440 Crate Drag Engine Options [Re: Chip] #2907236
04/06/21 11:57 AM
04/06/21 11:57 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would say nearly 100 lbs
2011 Drag Pak Challenger
