Ladderbar and scales? #2906293
04/04/21 02:15 PM
04/04/21 02:15 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Can you use scales to adjust ladderbar? My car is pushing the rear driver side tire flat then spins.
Re: Ladderbar and scales? [Re: bobs69] #2906496
04/04/21 07:14 PM
04/04/21 07:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it lauches straight the preload is OK. No need for scales. Does it go straight?
Doug
Re: Ladderbar and scales? [Re: dvw] #2906514
04/04/21 07:43 PM
04/04/21 07:43 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
It goes straight just pushes the driver side tire flat then will spin. Looks like there is a lot of weight on the driver side
Re: Ladderbar and scales? [Re: bobs69] #2906548
04/04/21 08:49 PM
04/04/21 08:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it goes straight scaling to change preload won't help. What is your combo, shocks, gear, power level, weight, tires?
Doug
