Hurst V-matic 2 question #2905923
04/03/21 06:48 PM
04/03/21 06:48 PM
Superfreak OP
Superfreak OP
Anyone know if the older Hurst V-matic 2 shifter will work with a manual reverse valve body? Have been looking on line and just can't find anything.
This a dual mode shifter.
Re: Hurst V-matic 2 question [Re: ] #2906048
04/04/21 10:05 AM
04/04/21 10:05 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
That's what I have in my Dart ....been there for over 30 years, with a Cheeta.
Burn out.
Roll into the water using the non ratchet mode put it in second, set line lock, whack it, pull back into 3rd, and let go of line lock power out of the water. lift, then push the shifter forward into neutral..
Stage and run
Push the shifter down, into ratchet mode, bang it backwards into first, stage the car, bang it backwards every time the shift light come on.
The non ratchet burnout has been great ...second ,to third ,to neutral without any stops/ratchets in between. And it's all against dead stop gates, no misses.
Re: Hurst V-matic 2 question [Re: B1MAXX] #2906282
04/04/21 01:51 PM
04/04/21 01:51 PM
moparx Offline
moparx  Offline
i'm kind of confused.
if you have a reverse pattern, how does third to neutral work without going back through 2nd and 1st ?
or do you have a clean neutral valvebody ?
beer
Re: Hurst V-matic 2 question [Re: moparx] #2906529
04/04/21 08:04 PM
04/04/21 08:04 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
all the way back {3rd} to all the way forward (neutral) right through all the other gears (detents) no stopping at any of the other gears.
With a ratchet only shifter you would have to ratchet 3 times momentarily stopping at each gear
