Scratch removal from clear coat question #290574
04/16/09 06:45 PM
04/16/09 06:45 PM
19704406 Offline OP
19704406  Offline OP
What is the best way to remove a scratch/grit wet sand paper to use to remove an 8 inch scratch from clear coat on a base/clear coat paint job? The scratch is not down to the base coat but is in deep on the clear. This happened in a Walmart parking lot from someone running a shopping cart handle down the side of the wifes SUV, this justs me.
All help is appreciated, thanks Ed
Re: Scratch removal from clear coat question [Re: 19704406] #290575
04/16/09 07:10 PM
04/16/09 07:10 PM
Long Island NY
yellow sixpack Offline
Long Island NY
You will always see it unless you bring it to the body shop.
If you can't be smart.....don't be stupid!
Re: Scratch removal from clear coat question [Re: 19704406] #290576
04/16/09 07:14 PM
04/16/09 07:14 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
You should be able to fill the scratch with some clear, then wet sand with super fine paper, then buff with compound and polish.It may still be visible some but should look better.
Al & Sheila
Re: Scratch removal from clear coat question [Re: 3twos] #290577
04/16/09 07:23 PM
04/16/09 07:23 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Take it to a body or detail shop and have someone who's good with a buffer work at it. I have seen some rather large scratches go away in the hands of the right person.
Re: Scratch removal from clear coat question [Re: 19704406] #290578
04/16/09 07:34 PM
04/16/09 07:34 PM
19704406 Offline OP
19704406  Offline OP
Thanks for the advice all is appreciated.
Re: Scratch removal from clear coat question [Re: Neil] #290579
04/18/09 12:06 AM
04/18/09 12:06 AM
Jacksonville Florida
elitecustombody Offline
+1 QFT
