Brake Fluid for Paint Remover?? #290561
04/16/09 06:11 PM
04/16/09 06:11 PM
Not2farfromNashville, TN
Rug_Trucker Offline OP
Thought I had some paint stripper to clean off an aluminum super six intake. I painted the top side with some brake fluid.
Will it work to remove the factory paint?
Will it harm the elctrowelded piece of crap factory intake?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Brake Fluid for Paint Remover?? [Re: Rug_Trucker] #290562
04/16/09 07:20 PM
04/16/09 07:20 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I'd just use paint stripper and a wire brush instead. Factory engine paint has no hardner in it and most of it should come off fairly easily.
Re: Brake Fluid for Paint Remover?? [Re: Rug_Trucker] #290563
04/16/09 07:37 PM
04/16/09 07:37 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
It would work but i would be worried with how the new paint would stick afterwards
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: Brake Fluid for Paint Remover?? [Re: sreinheimer] #290564
04/16/09 08:08 PM
04/16/09 08:08 PM
Brakekleen should fix that. I have several containers of open brake fluid. As humid as it gets here in TN? I won't use it if it is open for very long. Gotta get rid of the extra stuff.
Re: Brake Fluid for Paint Remover?? [Re: Rug_Trucker] #290565
04/17/09 08:10 AM
04/17/09 08:10 AM
Waterloo Iowa
8
80mirada Offline
80mirada  Offline
Waterloo Iowa
I've used brake fuid for years to strip model cars. just scrub it down good with soap and water afterwards.
Re: Brake Fluid for Paint Remover?? [Re: Rug_Trucker] #290566
04/17/09 08:28 AM
04/17/09 08:28 AM
Jacksonville Florida
elitecustombody Offline
go to Wal-Mart and spend $6 for aerosol can of paint stripper,it'll be alot faster
Re: Brake Fluid for Paint Remover?? [Re: elitecustombody] #290567
04/17/09 08:33 AM
04/17/09 08:33 AM
Money is tight. Got lots of open brake fluid!
I used some brush on stripper on another intake. It had less than stellar results. It wasn't cheap!
