Re: Don't give up on us
[Re: HOT IN AZ]
#2905695
04/03/21 10:02 AM
04/03/21 10:02 AM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Do you guys sell T-shirts? Would like to support you with a purchase. Hope you make it to Vegas! GOOD IDEA ... I’m in for at least one!
[Re: GomangoCuda]
#2905697
04/03/21 10:09 AM
04/03/21 10:09 AM
dOoC
Florida STAYcation
That article is confusing So NHRA wants to keep the track NHRA ... but it loses that national event if ownership is transferred? Me thimks they’ll be keeping that track LONG TIME ! This is not the financial climate to be selling something like this UNLESS it’s fire sale priced..... And NHRA very VERY rarely does that !
[Re: dOoC]
#2908578
04/10/21 12:17 AM
04/10/21 12:17 AM
Posts: 104 New Jersey
Alan Prusiensky
New Jersey
The truck and trailer is on its way to Vegas. I'm so excited to put the 2 Florida races behind me. Just to give you guys a idea what kind of work that we put in behind the scenes here you go.we came back from Gainesville and put the motor that was in my car on the dyno made 4 pulls junk. I worked on some valve train stuff. 4 more pulls the next day I liked what I seen. Take the motor apart I find something got number 3 cylinder put a new piston in that hole. Put the motor back on the dyno 4 more pulls back to the numbers it normally makes but better up around 10000. I did notice it had more blow by than normal but the numbers looked really good so I put it in the car and went to Mir made a run ran faster than I have ever run but the vacuum dropped bad in first gear. Came home took it apart 1 3 5 7 pistons were just touching the head in one spot and pinched the rings. Detailed the chamber to give it a little Clearnce and put the pistons in the lathe relieved a little bit above the ring land to protect the ring. Put the motor back together back on the dyno 4 more pulls. It averaged 20 better than my best. Take it apart again look over the pistons everything looks good back together in the trailer on the road.
[Re: Alan Prusiensky]
#2908605
04/10/21 06:49 AM
04/10/21 06:49 AM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Sounds like a lot of work. Best wishes on your next race !! AG
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#2908615
04/10/21 07:52 AM
04/10/21 07:52 AM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
Good Luck Alan ! , hope all your hard work pays off !!!
#2909368
04/12/21 08:16 AM
04/12/21 08:16 AM
Posts: 4,066 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
The truck and trailer is on its way to Vegas. I'm so excited to put the 2 Florida races behind me. Just to give you guys a idea what kind of work that we put in behind the scenes here you go.we came back from Gainesville and put the motor that was in my car on the dyno made 4 pulls junk. I worked on some valve train stuff. 4 more pulls the next day I liked what I seen. Take the motor apart I find something got number 3 cylinder put a new piston in that hole. Put the motor back on the dyno 4 more pulls back to the numbers it normally makes but better up around 10000. I did notice it had more blow by than normal but the numbers looked really good so I put it in the car and went to Mir made a run ran faster than I have ever run but the vacuum dropped bad in first gear. Came home took it apart 1 3 5 7 pistons were just touching the head in one spot and pinched the rings. Detailed the chamber to give it a little Clearnce and put the pistons in the lathe relieved a little bit above the ring land to protect the ring. Put the motor back together back on the dyno 4 more pulls. It averaged 20 better than my best. Take it apart again look over the pistons everything looks good back together in the trailer on the road. NICE!!! Good luck next race, looking forward to seeing the results.
#2909499
04/12/21 03:09 PM
04/12/21 03:09 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I'm sure many members on here do not know how muck work is involved to be able to compete at the level like you are in NHRA Pro Stock Let alone the the time and expenses involved in driving to and from the races and the actual time spent at the races to race the car Congratulations and keep up the good work
#2916768
04/29/21 10:38 PM
04/29/21 10:38 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Well we are back at it this weekend in georgia. Vegas was so bad I wanted to quite but maybe we finally figured out what has been killing us all year. The new wires that we got over the winter were not locking on the spark plugs unbelievable. It makes sense now it runs great on dyno runs and like [censored] in the car. I should have checked them on the dyno before I ran them in the car the little things get you every time. We have worked so hard on are engine program for the last year now the car is suffering. We are running two cars this weekend so we will have are hands full. If anyone is at the race come by and say hello. I think it was you last qualifying pass that caught my interest. Your ET wasn’t that great but unless there was an mistake on Drag Race Results your mph was up there with top top qualifiers.
