Page 1 of 3 1 2 3
car carrier ship cut up #2904573
03/31/21 12:05 PM
03/31/21 12:05 PM
Andrewh Online content OP
Andrewh  Online Content OP
The scale is amazing to me.
That truck in the lower right is a full size ram truck.
This ship turned on its side mid channel and got pushed onto a sandbar so it didn't block the channel.
they are cutting it up now, and this is only 1 chuck of it
https://www.caranddriver.com/news/a34847785/capsized-cargo-ship-salvage-watch/
Re: car carrier ship cut up [Re: Andrewh] #2904576
03/31/21 12:13 PM
03/31/21 12:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I read an article on it: they use a "cutting chain" to slice everything like a cake, than hoist each slice onto a barge. Amazing.
I'd always assumed that vehicles would be tied down for ocean voyages, but I guess not; or, the tie-downs were no match for a capsize.
Either way, that's a LOT of scrap metal to process.
Re: car carrier ship cut up [Re: topside] #2904578
03/31/21 12:16 PM
03/31/21 12:16 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
A real BIG reason why things should be made in the country they are supposed to sell in...
JB Rhinehart, Realist
A-Body's RULE!
Re: car carrier ship cut up [Re: Rhinodart] #2904582
03/31/21 12:30 PM
03/31/21 12:30 PM
Judging by the numbers, I guess it would take too long to tie everything down.
They said 4000 cars on it at the time, but it could hold 7000.
Re: car carrier ship cut up [Re: Andrewh] #2904588
03/31/21 12:44 PM
03/31/21 12:44 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So is the lack of tying the payload (cars) down a contributor to why the ship capsized in the first place?
So the rust stain is the water line marking the capsized immersion?
Re: car carrier ship cut up [Re: jcc] #2904597
03/31/21 12:57 PM
03/31/21 12:57 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have been following it on Youtube, although its a shame it happened I find the whole thing fascinating. I might be wrong but the pickup hanging out in the picture looks like a Ram.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: car carrier ship cut up [Re: 11secdart] #2904600
03/31/21 01:02 PM
03/31/21 01:02 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
From what I read about it, it was a ballast issue.
They off-loaded a bunch of small cars on one level or so, and loaded a bunch of SUVs & trucks at a higher level.
Making a turn, the ship started to roll over, and they couldn't save it.
Seems like a rookie mistake, which to me is surprising.
Re: car carrier ship cut up [Re: topside] #2904623
03/31/21 02:05 PM
03/31/21 02:05 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"couldn't save it" once the cars began to move? A simple center divider/guard rail on each level, might have saved the whole ship? eek
Re: car carrier ship cut up [Re: jcc] #2904626
03/31/21 02:12 PM
03/31/21 02:12 PM
CA
crackedback Offline
crackedback  Offline
CA
A longshoreman friend said they use to cut the straps holding the cars when he unloaded them. It was quicker than loosening the strap as they got X number of hours to unload. If they got a 8 hour job done in 4, they got paid for 8 like flag hours. That was 20+ years ago.
Not sure if the same securing methods are used now.
Re: car carrier ship cut up [Re: jcc] #2904646
03/31/21 03:25 PM
03/31/21 03:25 PM
it is questionable if the cars had moved by the time it was "too late".
the tipping point on a ship that size, may not be far enough to cause "sliding" like that.
The investigation isn't complete, but yeah, they said they accidently shifted the center of gravity too high by the change in cargo.
They also left a door open that helped contribute to the flooding and being unable to correct.
It sounded like the start of fish tailing to me. Tried to go one way, over corrected to go the other and didn't center the wheel soon enough and bam, gone.
Because they were so close to shore and other ships, was the only reason they are all alive. They basically said if it had happened out at sea, no one would have known what happened.
Re: car carrier ship cut up [Re: Andrewh] #2904665
03/31/21 04:42 PM
03/31/21 04:42 PM
hooziewhatsit Offline
Re: car carrier ship cut up [Re: Andrewh] #2904714
03/31/21 08:05 PM
03/31/21 08:05 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The investigation isn't complete, but yeah, they said they accidentally shifted the center of gravity too high by the change in cargo.
A lot of merit to your points, how about one of the car steel decks got wet. oily, Antifreeze, or the loaders left the cars in neutral/no brakes, and a snowball effect began with cars moving, unbeknownst to the ship operators who were dialing in the "normal" expected steering correction, and not understanding why things were not improving? Of course all speculative and without any proof, and likely will never be known for certain, which might be the goal of those who are to blame. Maybe the pilot has steering dyslexia? eek I would have thought the righting moment with a ship with this intended purpose, would have a large safety factor, but then, what do I know? grin
Re: car carrier ship cut up [Re: jcc] #2904717
03/31/21 08:11 PM
03/31/21 08:11 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Wow, I'm sure there's going to be plenty of blame to go around since there will be a HUGE financial loss.
Facts are stubborn things.
Re: car carrier ship cut up [Re: larrymopar360] #2904734
03/31/21 08:56 PM
03/31/21 08:56 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I noticed something else not yet noted, I found interesting in the OP's posted pic, there is not a single human visible, I assume underscoring the risk in this operation.
Re: car carrier ship cut up [Re: Rhinodart] #2904740
03/31/21 09:05 PM
03/31/21 09:05 PM
Kirkland, Washington
Pacnorthcuda Offline
Our EPA doesn’t understand that.
Re: car carrier ship cut up [Re: Pacnorthcuda] #2904833
04/01/21 07:51 AM
04/01/21 07:51 AM
I am not sure what that means. As I understand it, these were made here and being shipped to the middle east for sale.
if you are saying kia, mercedes and ram should open plants in the middle east, I am not sure how that helps us.
Re: car carrier ship cut up [Re: jcc] #2904862
04/01/21 10:26 AM
04/01/21 10:26 AM
IMGTX Offline
IMGTX  Offline
Yes and Yes.
I read a story on it and they loaded the cars on the upper levels while removing cars from the lower levels. Ship got top heavy and the tipped over mid trip.
It has been capsized for about a year IIRC, so that brown is the water line after flipping on it's side.
Re: car carrier ship cut up [Re: jcc] #2905067
04/01/21 07:59 PM
04/01/21 07:59 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I had to look,there is a guy in a yellow coat left side half way down. I had to look
Re: car carrier ship cut up [Re: SALEM1912] #2905310
04/02/21 11:22 AM
04/02/21 11:22 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Good Eye up
Re: car carrier ship cut up [Re: Rhinodart] #2905343
04/02/21 12:10 PM
04/02/21 12:10 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Different countries have different natural resources and capabilities so this is not always possible.
'63 Dodge 330
11.19 @ 121 mph
Page 1 of 3 1 2 3
