rear brake drums #290414
04/16/09 03:45 PM
04/16/09 03:45 PM
Mn, USA
3
340ShakerR/T Offline OP
Mn, USA
Here is my situation. I am restoring a '71 Challenger that has 4 wheel drum brakes. I has been modified with a Road Runner rearend with 11" finned brake drums. The original front drums are smooth. I would like to have the brake drums look original. Do they make an 11" brake drum that is not finned? I have ordered a set locally and they ended up being finned also. Would I be able to find these in a bone yard? If so what year & model should I look for?
Thanks.
Re: rear brake drums [Re: 340ShakerR/T] #290415
04/16/09 03:57 PM
04/16/09 03:57 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Ernie,
They do make unfinned 11" brake drums.
NAPA part # 640-1156.
Are you sittin down.
Figure about $150.00 EACH
NOt an easy itwem to find in the JY either. Most brake drums you find in the JY are pretty much trashed. But, you could get lucky.
Sorry for the bad news. Maybe someone here can get you a better deal. I know I had a difficult time finding them myself.
Good Luck,
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: rear brake drums [Re: 340ShakerR/T] #290416
04/16/09 04:00 PM
04/16/09 04:00 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Finned is the better drum as it will carry the heat away. Bring a drum mike with you to the yard if you have to go there. No use buying a drum if it is already worn out.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: rear brake drums [Re: Chi_Town_Runner] #290417
04/16/09 04:48 PM
04/16/09 04:48 PM
Mn, USA
3
Mn, USA
Great advise, thank you.
Re: rear brake drums [Re: 340ShakerR/T] #290418
04/16/09 11:37 PM
04/16/09 11:37 PM
Chicagoland
cudastruction Offline
Chicagoland
I have an original 8 3/4" rear end in my 71 cuda with 11" drums and they are finned (still have the factory red paint). Why do you want ones without the fins? I assume the Chally and Cuda drums would be the same...
