Oil/trans fluid recommendations?
#2902504
03/24/21 08:47 PM
03/24/21 08:47 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Working on my Demon, about to be ready to drop in engine/trans. Looking for what oil and trans fluid to use. ‘72 Demon all steel, glass hood, stock interior. 360, .30 over 4.125 stroke crank (420 cubes) Eddy heads, Hughes stage 2 porting, super victor gasket matched, 820 Holley. 10.5:1 Comp. Bullet hyd roller cam .249/257 @ .050 .573 lift. 904 trans, rev. valve body, PTC 3800-4000 rpm stall converter. 4.30 gear, 275/60-15 Drag radial.
Is the synthetic worth the $$? Thanks all!
Wally.
Re: Oil/trans fluid recommendations?
[Re: wkroncke17]
#2902590
03/25/21 08:24 AM
03/25/21 08:24 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I use Valvoline VR1 race oil and whatever brand of Type F trans fluid I can get my hands on. I used to use Mobil One synthetic motor oil, but for a while it got real hard to find...so I switched to the Valvoline. Bearings still look great w/ it, so I have kept using it.
[Re: wkroncke17]
#2902717
03/25/21 02:24 PM
03/25/21 02:24 PM
Posts: 16,928 NC
440Jim
NC
IMO, for your case NO. The transmission fluid choice depends on the chance you could overheat it. A mild footbrake car with medium to low stall is unlikely to overheat the trans/converter.
[Re: wkroncke17]
#2912737
04/21/21 06:53 AM
04/21/21 06:53 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
the car looks really good!
I have used several different types of oil. I usually throw Rotella 15W40 in it when I do drag week where it will see the highest oil temps it ever sees. Its cheap to change and the 15W40 offers a good balance for on track oil pressure and been on the highway for 3 hours oil pressure(in my combo). But when I am not putting a ton of miles on it I run 5W30 to keep my oil pressure out of the moon when I am racing and the oil temp isn't that high.
For trans fluid I use wal mart Type F.
68 Barracuda Formula S 340
[Re: dvw]
#2913147
04/21/21 08:28 PM
04/21/21 08:28 PM
Posts: 2,515 PA
moparacer
PA
I dont get too excited about oils, but I only bracket race. I switched to the Valvoline Max Life synthetic that Walmart carries last year after I got tired of chasing Type F. $18.00 a gallon, on the shelf anytime I need it and so far is working fine in my glide running mid 5's in the 1/8 mile.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
