Re: Hemi block stampings
[Re: Felix]
#2902256
03/24/21 03:12 AM
03/24/21 03:12 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
MN Eng plant Maryville Michigan
3021 Nov.4 1969
58271 Unit build number Year 1970
What if any are the other numbers with this number. on the oil pan rail.
When was the block cast, side of block Month Day Year.
What are the markings on the front pad near the distributor.
Do you think the block was assemble at Chrysler or do you think if was sold with out being assembled.
1971 HEMI E BODY REGISTRY
[Re: Felix]
#2902451
03/24/21 05:56 PM
03/24/21 05:56 PM
hemicar1971
Chicago Blackhawks
So there ia no other numbers or letters on the pan rail below this number. I believe it falls into a 1970 Vehicle. I do not have that serial number written down for a 1971 Hemi E Body, but that does not mean someone might. Barry Washington or Dan Paush on moparts collect 1970 Chrysler information and they might be able to shed more information your way if a 1970 Hemi Built black. To bad you dont have that one number ahead of the serial number you posted. 0B187972 or 1B187972.
