Re: 1970 Dodge Sweptline door hinge rebuild kit?
[Re: earlymopar]
#2905717
04/03/21 11:02 AM
04/03/21 11:02 AM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Tried that, email address already in use..... I searched for an old thread I was in, found it to recover my username, after that a password re-set was possible. :-) My last post there was back in 2009.
[Re: Alaskan_TA]
#2907506
04/06/21 10:21 PM
04/06/21 10:21 PM
Posts: 177 Norfolk County , Ontario
WORKER_BEE
If you want another option, Vintage power wagons show that they have a hinge pin and bushing kit for D & W models. They categorize these under Vehicle Type G. The part number is #CC6013035 and can be found on page 87 here... Linky
1969 Super Bee Six Pack 1969 Charger R/T SE 1968 Crown Coupe
[Re: WORKER_BEE]
#2907811
04/07/21 07:32 PM
04/07/21 07:32 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
If you want another option, Vintage power wagons show that they have a hinge pin and bushing kit for D & W models. They categorize these under Vehicle Type G. The part number is #CC6013035 and can be found on page 87 here... Linky Most of the cabs used on the vintage Power Wagons were the old 39-47 cabs. Dodge used those cabs on military trucks up through the end of the 1968 model year. Dodge did use the regular truck cabs after 69, be sure the hinge pin will work on the 69 - 71 cab. I would call and talk with someone at Vintage Power Wagons to be sure, they are good people. Be sure to tell them you have a 70 or 71 Power Wagon. The hinge pins should be the same, 4x4 or 2x4. Gene
