Convertible Top Pump Fluid type #2901995
03/23/21 11:55 AM
03/23/21 11:55 AM
Sin City
calif67rt Offline OP
Sin City
In my service manual (67 Coronet) it says the fluid to be used in the convertible top pump is auto trans fluid AQ-ATF Suffix "A". I called the local parts store and they said that Valvoline Max Life tranny fluid would be the same. Is that correct? What do you folks use?
Re: Convertible Top Pump Fluid type [Re: calif67rt] #2902025
03/23/21 01:07 PM
03/23/21 01:07 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
I used Type F fluid in my '68. Just got some cheap Walmart fluid.
Re: Convertible Top Pump Fluid type [Re: calif67rt] #2902026
03/23/21 01:09 PM
03/23/21 01:09 PM
IMGTX Offline
IMGTX  Offline
I used Dextron II in mine years ago. Virtually any older straight normal fluid will be ok. It is just a basic hydraulic fluid in that application.
Beware of any fluid that advertises high mileage. Those oils usually have additives that will cause the seals to swell and can cause problems when there weren't any in the first place.
Re: Convertible Top Pump Fluid type [Re: IMGTX] #2902081
03/23/21 03:19 PM
03/23/21 03:19 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
This might help
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Convertible Top Pump Fluid type [Re: RealWing] #2902374
03/24/21 01:18 PM
03/24/21 01:18 PM
Sin City
Sin City
Thanks for the reply's. It is all very helpful.
