440 Balancing #2901944
03/23/21 10:43 AM
03/23/21 10:43 AM
Wichita, KS
tmef Offline OP
tmef  Offline OP
Wichita, KS
My 440 was originally out of a motor home. It is a 1974 with a forged crank. It had six pack rods. I took it .030 and used cast pistons with LY rods. Would you have gotten the rotating assembly balanced? I am thinking of taking it .040 over with forged pistons. Would you have it balanced then?
Re: 440 Balancing [Re: tmef] #2901952
03/23/21 10:59 AM
03/23/21 10:59 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Any time you deviate from a stock component in the reciprocating assembly that doesn't have the OEM weight, you should rebalance.
Re: 440 Balancing [Re: 6PakBee] #2901965
03/23/21 11:13 AM
03/23/21 11:13 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd balance even a stock rebuild, but I can't leave anything alone... laugh2
Re: 440 Balancing [Re: tmef] #2901971
03/23/21 11:31 AM
03/23/21 11:31 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
It really all depends on how you are going to use the engine. I have swapped out factory cast pistons for hypertic or forged pistons before and didn't rebalance. I have also broken a motor and needed to be racing the following week. At the time my dad had a box full of stock rods and factory cast pistons. We just mixed and match a set to get an engine together. I mainly drag race so I spin my engines up to 6000 or so. Now these engines aren't are smooth as they could be, but not sure they were any worse than some of the OEM balance jobs. I once used a shop to balance my assembly and it wasn't any smoother than some of the motors I slapped together. The shop I use now the guy is super picky about the balance job and those motors are SMOOTH. I'll balance all of my stuff from now on, just mainly because it's hard to find good unabused OEM stuff to slap together.
Re: 440 Balancing [Re: 6PakBee] #2901972
03/23/21 11:31 AM
03/23/21 11:31 AM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 Balancing [Re: an8sec70cuda] #2902031
03/23/21 01:14 PM
03/23/21 01:14 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Balance it.
Re: 440 Balancing [Re: tmef] #2902062
03/23/21 02:38 PM
03/23/21 02:38 PM
A727Tflite Offline
A727Tflite  Offline
If the current engine doesn’t have any vibration issues then compare the new piston against the old.
With a gram scale, assuming the new pistons are heavier, you can match the the new pistons to the old.
No need to balance the whole assembly then.
Re: 440 Balancing [Re: tmef] #2902067
03/23/21 02:56 PM
03/23/21 02:56 PM
Are you feeling really lucky or hoping to get lucky shruggy
Do it correctly once or maybe, probably, have to do it over later twocents
I always cost more later to do it over work
Re: 440 Balancing [Re: Cab_Burge] #2902079
03/23/21 03:16 PM
03/23/21 03:16 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Can you destroy an engine without balancing?
China is the enemy.
Re: 440 Balancing [Re: 1972CudaV21] #2902106
03/23/21 04:40 PM
03/23/21 04:40 PM
A727Tflite Offline
A727Tflite  Offline
Depends how bad it is out, and long you run it and at what engine speed.
I would think most people would not drive it long enough if it vibrated badly.
But then again.........
Re: 440 Balancing [Re: 1972CudaV21] #2902147
03/23/21 06:08 PM
03/23/21 06:08 PM
Abilene, Texas
Abilene, Texas
A friend bought a 69 charger 4 speed car that had a cast crank externally motor in it when he bought it. It vibrated. The car had the original neutral balance flywheel. It beat the bearing out of the hub for the pilot bearing and may have damaged the transmission. The rear main leaked as well. Suprisingly, the main bearings looked ok.
Re: 440 Balancing [Re: Cab_Burge] #2902159
03/23/21 07:08 PM
03/23/21 07:08 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree I don't know how much balancing would cost where you are, but I've never seen a price so out of line that I wouldn't do it. My 440 was balanced with the damper and flywheel, and it runs incredibly smooth, I thought it was money well spent.
If some how the price is outrages or this is an engine that "doesn't need it" I'd at least do what Transman suggests twocents
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: 440 Balancing [Re: metallicareload] #2902281
03/24/21 08:58 AM
03/24/21 08:58 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Some people over balance, add extra bob weight. Some under balance , remove bob weight. The factory tolerance cylinder to cylinder is not spot on. How much can you get away with? Obliviously the factory specs work. Engines run a long time being untouched. Now lets say the new pistons are close or slightly under in weight. Is it a big deal being under balanced, probably not. Where you get into trouble is like a cast crank scenario. The bob weight is far greater than the crank counterweight mass. In this case extra counter weight mass must come from the flex plate, converter, flywheel, balancer. Is balancing a bad thing? No. Is it absolutely necessary when weights are close in a street application? In my opinion, no.
Doug
Re: 440 Balancing [Re: dvw] #2902283
03/24/21 09:12 AM
03/24/21 09:12 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What I think you have to keep in mind that the magnitude of any unbalance increase as the square of the speed. Double the speed, four times the force due to unbalance. So if you have an engine that never gets over 4000 rpm, it can tolerate considerably more unbalance than an engine turning 8000 rpm.
