How much trans oil should I need for a filter swap?
#2901901
03/23/21 08:54 AM
03/23/21 08:54 AM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I'm questioning the oil level indicator on my trans dipstick. I'm not sure if it's the correct dipstick for a 1971 426 Hemi trans as I'm told they are different from others. So, if I drop the trans pan for a filter swap only, how much trans fluid should I be expected to put in?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: How much trans oil should I need for a filter swap?
[Re: IMGTX]
#2902171
03/23/21 08:23 PM
03/23/21 08:23 PM
Posts: 15,451 Omaha Ne
TJP
Omaha Ne
I can answer the question. If you buy 6 quarts, you'll need 8. If you buy 10 quarts you'll need 5 As mentioned there are too many variables to give an accurate answer.
[Re: IMGTX]
#2902202
03/23/21 10:08 PM
03/23/21 10:08 PM
RSI700VIPER
NW New Jersey
Standard capacity for a 727 with a stock pan is about 5 quarts. If you are gonna change the filter and fluid go ahead and drain the convertor if it has a drain plug. It is behind the flat shield, behind the oil pan, on the transmission housing face. You may have to rotate the engine to find the small drain plug. Not all torque convertors have them today but the factory did back in 1970.
Draining the torque convertor will add between 2 and 4 quarts to the 5 above depending on the size.
I can't find a good picture but the dipstick should extend into the transmission about 3/4 of inch or so. Here is a small block tube for reference. The level for a 727 will be the same for all engine types.
The difference in a Hemi Dipstick should be the shape of the tube not the depth of the fluid.
John Kunkel is the resident Auto Transmission expert and may have better advice/pics. Good picture. I guess the question is if all dipsticks protrude past the tube the same distance. I understand '71 Hemi auto transmissions are a bunch of new and old hemi parts pulled together.
[Re: IMGTX]
#2902488
03/24/21 08:26 PM
03/24/21 08:26 PM
RSI700VIPER
NW New Jersey
GTX - The problem is it's a '71 Hemi trans. I understand hemi auto's holds 6 quarts but not because the pan is deeper which adds to the confusion. My pan looks exactly like the pan on my 440, no difference in depth so where does the other quart go? The extra hemi cooler doesn't look like it can carry another quart but maybe 1/2 quart? And from other posts, the dipstick is a different on a 70-71 hemi vs 67-69. If I could empty the entire system, then add 6 quarts, then mark the stick wherever the level is would solve the problem but getting everything out sounds like a lot of work.
[Re: RSI700VIPER]
#2902542
03/24/21 11:18 PM
03/24/21 11:18 PM
Posts: 1,330 VA
dragon slayer
VA
GTX - The problem is it's a '71 Hemi trans. I understand hemi auto's holds 6 quarts but not because the pan is deeper which adds to the confusion. My pan looks exactly like the pan on my 440, no difference in depth so where does the other quart go? The extra hemi cooler doesn't look like it can carry another quart but maybe 1/2 quart? And from other posts, the dipstick is a different on a 70-71 hemi vs 67-69. If I could empty the entire system, then add 6 quarts, then mark the stick wherever the level is would solve the problem but getting everything out sounds like a lot of work. I hope that was not my post, I misread the trans discussion and posted about the Oil pan stick. According to the parts book, the hemi trans dipstick was the same part number 66-71. The tube changed in 69.
[Re: dragon slayer]
#2902620
03/25/21 10:52 AM
03/25/21 10:52 AM
RSI700VIPER
NW New Jersey
GTX - The problem is it's a '71 Hemi trans. I understand hemi auto's holds 6 quarts but not because the pan is deeper which adds to the confusion. My pan looks exactly like the pan on my 440, no difference in depth so where does the other quart go? The extra hemi cooler doesn't look like it can carry another quart but maybe 1/2 quart? And from other posts, the dipstick is a different on a 70-71 hemi vs 67-69. If I could empty the entire system, then add 6 quarts, then mark the stick wherever the level is would solve the problem but getting everything out sounds like a lot of work. I hope that was not my post, I misread the trans discussion and posted about the Oil pan stick. According to the parts book, the hemi trans dipstick was the same part number 66-71. The tube changed in 69. DS - There is a 4202951 part number stamped on my dipstick just below the rivets. Do I have the correct dipstick?
[Re: dragon slayer]
#2902800
03/25/21 08:24 PM
03/25/21 08:24 PM
TJP
Omaha Ne
[Re: IMGTX]
#2903891
03/29/21 08:58 AM
03/29/21 08:58 AM
RSI700VIPER
NW New Jersey
I did a little more checking since I was home near my parts books and all the Hemi's from 67 to 71 used the same part number dipstick. I believe 68 Jim posted his dipstick was in the neighborhood of 14" so the hemi stick is shorter than other engines. Excellent Info GTX. Thanks. I must say though, the stick section cut and rivets look factory.
[Re: RSI700VIPER]
#2903892
03/29/21 09:02 AM
03/29/21 09:02 AM
RSI700VIPER
NW New Jersey
Funny that on my dipstick, there is an "M" stamped after the part number. M for Modified?? My '71 Hemi carbs are actually 1970 carbs modified for the 1971 Hemi with an "M" stamped in front of the part number. I understand that this is factory correct for a '71 Hemi.
[Re: RSI700VIPER]
#2903920
03/29/21 10:45 AM
03/29/21 10:45 AM
Posts: 12,237 Looking for a way out of Middl...
IMGTX
At least one of my dipsticks had an M stamped on it. Maybe it's a stamp from whomever made it or? None of mine had Rivets though. It is common on some manufacturers factory dipsticks to have rivets but I can't recall one way or the other any from Mopar back in the 70's so I can't say for sure.
[Re: dragon slayer]
#2904252
03/30/21 11:01 AM
03/30/21 11:01 AM
RSI700VIPER
NW New Jersey
That is what I said earlier. The stick is the same, the tube chanced as they went from bolt on to press on tube. Isn't M mopar performance part numbers. DS - Here is the dipstick with the part number and the "M". The M might not even be associated with the part number.
