Re: Dropping Steering Column
[Re: 70B Body]
#290176
04/16/09 11:39 AM
04/16/09 11:39 AM
RapidRobert
Check if you need to unplug your column wiring harness(es)
[Re: RapidRobert]
#290177
04/16/09 11:46 AM
04/16/09 11:46 AM
Posts: 31 Iowa
70B Body
Iowa
Just reread your post what I think you are doing wrong is ,the two you removed from the oval washer looking thing can stay in.But the four bolts behind them that go through the fire wall have to come out.
1970 Satellite 383/AT
