Powerglide to Small Block Mopar #2901428
03/21/21 08:20 PM
03/21/21 08:20 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
I have a question about a Reid Small Block Mopar Bellhousing and a Meziere Billet Flexplate. My starter does not fit and I need to know what I'm missing.
The flexplate is bolted directly to the crankshaft.
The Converter fits real nice, perfect clearance.
Do I need to run a spacer between the starter and the bellhousing?
Re: Powerglide to Small Block Mopar [Re: Biginchmopar] #2901435
03/21/21 08:57 PM
03/21/21 08:57 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I run the JW bell housing and I have to run 1 3/8 flat washer on the top and bottom bolt to space the starter back away from the flex plate and i have not had any problems most people run a mid plate and that space it away from the starter to
Re: Powerglide to Small Block Mopar [Re: scottb] #2901461
03/21/21 10:56 PM
03/21/21 10:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My JW bell came with a pack of 1/8 “ spacers. I had an 1/8 steel mid plate, used two spacers because starter went to deep.
Re: Powerglide to Small Block Mopar [Re: cudaman1969] #2901470
03/22/21 12:17 AM
03/22/21 12:17 AM
Carson City, Nevada
Carson City, Nevada
Here is a question I need somebody to answer.
Has anybody used a Reid Bellhousing with a steel .100" miidplate and a Meziere Billet Flexplate?
I'm having fitment issues and need some help.
Re: Powerglide to Small Block Mopar [Re: Biginchmopar] #2901488
03/22/21 07:36 AM
03/22/21 07:36 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
PM me your email address and I will send you some pics of what I had to do on my BB Reid bell, Meziere flexplate combo.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Powerglide to Small Block Mopar [Re: Biginchmopar] #2901721
03/22/21 05:44 PM
03/22/21 05:44 PM
NC
440Jim Offline
440Jim  Offline
NC
What does fit with the starter?
- Does the nose bottom in the bellhousing before the body bolts flat to the mounting surface?
- Does the body bolt flat, but the starter gear does not engage the ring gear? i.e. starter too far away or ring gear too close
- Is that the flexplate with ring gear that Reid recommends with there PG bellhousing/case?
- Many PG conversions require shimming the starter, and if lots of shims are needed, a starter nose extension is used.
FYI, attached is from the company that makes my PG converter.
If the flexplate is too far from the converter, washer/spacers are used. With my setup, I used 1/4" flat spacers.
