Ebody hemi booster offset bracket
#2899855
03/16/21 08:33 PM
03/16/21 08:33 PM
Posts: 1,102 Ont, Canada
moparo
Ont, Canada
Is there any one making these brackets?
performancecarrestorations.com
Re: Ebody hemi booster offset bracket
[Re: moparo]
#2900016
03/17/21 11:10 AM
03/17/21 11:10 AM
Posts: 704 WV
Little Detroit
WV
the repro booster bracket leaves a lot to be desired
[Re: dragon slayer]
#2900042
03/17/21 12:30 PM
03/17/21 12:30 PM
Posts: 18,157 Mass
DAYCLONA
Mass
The only difference between B and E is the petal center link length. Not sure many are reproducing these anymore. They are using the generic one I think with the smaller booster bolt pattern. If you find one make sure it has the pattern of the booster you are using. I use to repro both brackets years ago, not anymore....IIRC DrDiff also offers both sized brackets MikeG
