RV2 AC Compressor or new style rotary . . . #2897351
03/09/21 12:14 PM
03/09/21 12:14 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
If you have a RV2 compressor on your car (factory AC), and AC works . . .would you leave it alone ?? (system already changed to R134) or would you go to the newer rotary style compressor (takes less hp to run, less weight on front of engine, etc. . . ) . . .
Re: RV2 AC Compressor or new style rotary . . . [Re: a12rag] #2897354
03/09/21 12:27 PM
03/09/21 12:27 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
If it ain't broke don't fix it....
Or my favorite, if it ain't broke, you're not trying!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: RV2 AC Compressor or new style rotary . . . [Re: GTSDart340] #2897357
03/09/21 12:36 PM
03/09/21 12:36 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I am just too much of an anal purist. I'd stick with the original. The only thing I would question is if the shaft seal is compatible with R-134A.
Re: RV2 AC Compressor or new style rotary . . . [Re: 6PakBee] #2897359
03/09/21 12:43 PM
03/09/21 12:43 PM
a12rag Offline OP
a12rag  Offline OP
That is great question on the shaft seal . . . I guess I should not complain, I finished the car in 2013 (and have put on 10k miles) and now I see evidence of pag oil on the front of the compressor, so time for the shaft seal to be replaced . . . hence the question, just do the seal (ones today say compatible with R134), or convert to the Sanden rotary . . . but as you say, its all there in place and nothing else wrong . . . probably order up the shaft seal and talk to my local AC shop . . .
Re: RV2 AC Compressor or new style rotary . . . [Re: a12rag] #2897376
03/09/21 01:33 PM
03/09/21 01:33 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
If it was working and my engine bay was as pretty as that one--no way I would tear it apart to fix some thing that wasn't broken.
If it starts to go, then maybe I would look at some options.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: RV2 AC Compressor or new style rotary . . . [Re: wingman] #2897406
03/09/21 03:25 PM
03/09/21 03:25 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I remember turning on the AC on my RV2 cars, and it was like their 383s were lighting off a Harley.
My rotary-compressor cars (GM stuff) were noticeably smoother in operation.
But for an original car, I wouldn't change it unless I had to use the AC often and for extended periods.
If I had a "driver" car with some other mods, I'd update the AC without regret.
OR -just save the old stuff, and except for car shows, you're fine.
But if the RV2 doesn't bother you & it's not broken, take my opinion with a large dose of salt, as the saying goes...
Re: RV2 AC Compressor or new style rotary . . . [Re: a12rag] #2897440
03/09/21 05:14 PM
03/09/21 05:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Keep in mind that you need to install a clutch cycling switch if you use other than the RV2 compressor.
Re: RV2 AC Compressor or new style rotary . . . [Re: John_Kunkel] #2897467
03/09/21 07:08 PM
03/09/21 07:08 PM
BDW Offline
BDW  Offline
[quote=John_Kunkel]Keep in mind that you need to install a clutch cycling switch if you use other than the RV2 compressor. [/quote
Why is that?]
Re: RV2 AC Compressor or new style rotary . . . [Re: BDW] #2897500
03/09/21 08:23 PM
03/09/21 08:23 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
If I had a functional RV2 setup, I'd simply repair it.
Especially on a driver or cruiser.
If I was building from scratch a full function touring car I would go newer. But that would be accepting that everything is going to be custom.
Angry white pureblood male
Re: RV2 AC Compressor or new style rotary . . . [Re: ruderunner] #2897537
03/09/21 09:41 PM
03/09/21 09:41 PM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
The RV2 will pump more gas than the sanden by a reasonable percentage, leave it alone...
Is that a propane converter behind the battery?
Re: RV2 AC Compressor or new style rotary . . . [Re: BDW] #2897556
03/09/21 10:20 PM
03/09/21 10:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why is that?]
The system will freeze up. The RV2 has a valve that keeps that from happening.
Re: RV2 AC Compressor or new style rotary . . . [Re: Alchemi] #2897599
03/10/21 01:07 AM
03/10/21 01:07 AM
a12rag Offline OP
a12rag  Offline OP
No, that factory cruise control transducer
Re: RV2 AC Compressor or new style rotary . . . [Re: a12rag] #2899630
03/16/21 11:02 AM
03/16/21 11:02 AM
BDW Offline
BDW  Offline
If it works I'd leave it alone, only benefit is weight reduction.
Here's info from when I converted over
Re: RV2 AC Compressor or new style rotary . . . [Re: 6PakBee] #2899651
03/16/21 12:01 PM
03/16/21 12:01 PM
IMGTX Offline
IMGTX  Offline
Shaft seals on AC Compressors are not lip seals like you would see on a low pressure seal like a main seal. They are a type of seal that looks a lot like the seamless ring seals in a transmission.
They should be R134a resistant because they are not rubber. Side note: Never handle a compressor seal with your hands. According the manufacturers, it ruins them.
I have converted a lot of systems over to R134a and I have not had a leak at the compressor shaft seal.
All have leaked down over time much faster than an R12 system would. It may be the smaller molecules escaping through the hoses not designed for R134a or the fact that R134a tends to run higher pressures and the result is small leakage.
Mineral oil was used in R12 systems. Mineral oil will not carry in R134a so it settles in the bottoms of the compressor, drier, and cores. So you will need to change the oil or at least run Ester oil. PAG and Mineral oil are not compatible together.
Fill your system by pressure not the quantity, books will tell you 80% R134 to what the original R12 system used but that is usually too much. Pressures are temperature dependent.
All that said I have no problem using the old system if I want it to look stock but it will never cool as good as a properly functioning R12 system.
If you want the absolute best using R134a gas, then install a matched component system made for R134a.
My twocents
Re: RV2 AC Compressor or new style rotary . . . [Re: IMGTX] #2899692
03/16/21 01:41 PM
03/16/21 01:41 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Can you still drive into Canada or Mexico and get it recharged with R12? Asking for a friend
Re: RV2 AC Compressor or new style rotary . . . [Re: cudaman1969] #2899695
03/16/21 01:44 PM
03/16/21 01:44 PM
IMGTX Offline
IMGTX  Offline
From what I have they refill it with Propane. Rumor has it.. wink wink
Propane is an excellent refrigerant. It's just against the law to use it in a car, but so is speeding and they don't have a radar gun for propane. LOL stirthepot
Re: RV2 AC Compressor or new style rotary . . . [Re: IMGTX] #2899742
03/16/21 03:24 PM
03/16/21 03:24 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Around here, little cans of R12 go for about $20 each. Seems like no big deal unless you have a leaker.
Re: RV2 AC Compressor or new style rotary . . . [Re: cudaman1969] #2899774
03/16/21 04:56 PM
03/16/21 04:56 PM
a12rag Offline OP
a12rag  Offline OP
I am in Canada . . . and it's all R134 up here, as far as I know. When I put the car together, all AC components were NEW, with R134 compatible hoses, seals, etc . . .
Re: RV2 AC Compressor or new style rotary . . . [Re: ruderunner] #2901004
03/20/21 09:21 AM
03/20/21 09:21 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Same here. A scratch build would see (you would have to squint) a sanden mounted under the alternator where the fuel pump used to be.
Re: RV2 AC Compressor or new style rotary . . . [Re: DaytonaTurbo] #2901033
03/20/21 11:49 AM
03/20/21 11:49 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Ever wonder why it's against the law? Propane is highly flammable and anything that breaks a line and can ignite it then you have a fireball under your hood! R134 uses a higher operating pressure than does R12. So if the time comes where you might need to do some work to the ac system it's wise to use a compressor that is made for 134a. If you have a 6 pack or hemi the choice is simple because you don't have the option.
