edelbrock carb gasket #2899050
03/14/21 02:25 PM
03/14/21 02:25 PM
British Columbia
Y
yellowgtx Offline OP
Y
British Columbia
Does anybody have a source for the fuel inlet gasket on the Edlebrock carbs. . I have a couple of the Edelbrock 3/8" fuel inlet fittings but cant find a place to order the gaskets. New ones did not come with my carb kit.
After almost 71 years I am on my last car. A 65 Plymouth Satellite straight axle altered wheel base car.
Re: edelbrock carb gasket [Re: yellowgtx] #2899060
03/14/21 02:55 PM
03/14/21 02:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What size is the threaded fitting?
Re: edelbrock carb gasket [Re: NITROUSN] #2899070
03/14/21 03:21 PM
03/14/21 03:21 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Re: edelbrock carb gasket [Re: NITROUSN] #2899388
03/15/21 03:11 PM
03/15/21 03:11 PM
British Columbia
Y
Y
British Columbia
I believe it is the 5/8 X20 one.
Re: edelbrock carb gasket [Re: yellowgtx] #2899414
03/15/21 04:53 PM
03/15/21 04:53 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Bought an AFB that had boogered threads. Found the tap on ebay. 5/8 x 20 was what I used to clean them up.
