One of the things of concern for the future is the 50 year old trans shifts too low, even though I'd adjusted the kickdown to the FSM procedure (same as this cute one
https://www.youtube.com/watch?v=KsfI9cFFPpg) when I did the bands oil and filter. Just guessing, but the pressure might be a little low with old seals and worn parts. At WOT it goes 1-2 and 2-3 at about 3000 rpm, and actually does not kick down very easily. I've also noted that on the flat it starts out in second unless full throttle (I can shift the lever and it drops).
If anyone knows or has a source for proper values at the outside tap ports I would check them.
Any other test suggestions are welcome.
It is hard to gauge shift behavior of a 11,000 lb rig, but it seems smooth without hesitation or clunks etc. My B3500 is firmer, but had a shift kit and only weight 5,400.
This is part of my impetus for the other OD thread; if it has to come out, what to do?
