Re: Big Block Edelbrock RPM Heads
[Re: tmef]
#2898471
03/12/21 02:55 PM
03/12/21 02:55 PM
Posts: 17,845 S.E. Michigan
ZIPPY
S.E. Michigan
I got them when they first came out, and they're still working fine.
'69 b body, I tried two sets of headers and two exhaust (among other things) in the pursuit of speed.
For spark plug socket clearance....2 small dings required with hooker competition b body, none required with 2" super competition b body.
Before bolting in a car, put the heads on a bench, bolt the header on and make whatever adjustments you need to make to change spark plugs. Or do it on an engine stand.
Rich H.
Esse Quam Videri
[Re: lewtot184]
#2898554
03/12/21 07:39 PM
03/12/21 07:39 PM
Posts: 9,117 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
i'm running a pair on a 440 in my '65 coronet. i use 2" tti headers and the angle plugs fit nicely. i Same here. '65 Belvedere.
[Re: tmef]
#2898560
03/12/21 08:07 PM
03/12/21 08:07 PM
Posts: 12,084 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I also got a set when they first came out. They have been on 3 different engines now and were ported by MCH. No problems at all with them. 2" TTIs fit just fine.
Master, again and still
[Re: Dcuda69]
#2898861
03/13/21 10:53 PM
03/13/21 10:53 PM
Posts: 116 Eastern Shore of Maryland
nasty68
Been running them in my dart with a 383 and pro parts headers. Had to ding the headers a few places but not due to the angle plugs.
68 dart, 383, 727 2013 Jeep JKU Sahara
[Re: dvw]
#2898929
03/14/21 07:49 AM
03/14/21 07:49 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Got them on a 521ci motor in a C-Bod weighing in at over 4000lbs. Daily driver around London Town and yes its been down the strip, in full street trim. OK it was a hot day and we didn't do any prep, 13.20. TTI C-Bod headers fitted like a GLOVE! Nearly forgot the best bit, 950cfm carb and 16mpg...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
