NASA reveals what exploded over Vermont scary to say the lea
#2898320
03/12/21 12:27 AM
03/12/21 12:27 AM
Posts: 21,499 N.E. OHIO, USA
A12
N.E. OHIO, USA
Re: NASA reveals what exploded over Vermont scary to say the lea
[Re: A12]
#2898325
03/12/21 12:52 AM
03/12/21 12:52 AM
Posts: 16,813 Between Houston & Galveston TX
SattyNoCar
We're in big trouble if a really big one finds us............again
As screwed up as this country (world?) is right now, it might be an improvement.
Interesting read though.
John
[Re: BSharp]
#2898380
03/12/21 11:19 AM
03/12/21 11:19 AM
Posts: 22,696 Bitopia
jcc
Bitopia
F=MV^2. When the V is 12 miles per second, it doesn't take much M to F up your day. I remember vaguely a IMO useful example, which would you rather be struck by ( the numbers here are out of thin air, but the intended point remains valid I believe), which would you rather be struck by, 100,000 ton ocean freighter going 25mph, or a 100,000lb Concorde jet doing 1500 mph?
[Re: Mastershake340]
#2898412
03/12/21 12:20 PM
03/12/21 12:20 PM
Posts: 3,880 Oregon
hooziewhatsit
42.000 miles per hour (19 kilometers per second).
Stuff in low earth orbit is moving at 7.8km/s. This was moving a bit over twice as fast as that. And probably came in at a steeper angle too.
big-badda-boom
[Re: hooziewhatsit]
#2898483
03/12/21 03:19 PM
03/12/21 03:19 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
It is all about the total energy transferred to the atmosphere and how fast. Just like your car, you can stop it basically instantly from 100 mph by hitting a solid mountain cliff and it will cause great destruction to the car or you can disapate that same energy with the little bitty brake pads against the rotors more slowly and nothing gets harmed except some very tiny amount of pad and rotor wear and some heat released into the atmosphere, the same amount of energy is dissipated either way. If the rock hits the earth directly at 20 miles per second it will make a much larger explosion than the same size mass traveling 1/2 the speed and gently easing into the atmosphere at an angle. The way stuff is just flying around in the galaxy something very small could hit the earth and cause major destruction. They say the earth is flying around at thousands of miles per hour relative to the sun, something very small traveling equally fast in the opposite direction could hit with some serious energy and would be much harder to detect ahead of time than a large object traveling relatively slow with the same amount of energy.
[Re: HotRodDave]
#2898495
03/12/21 04:25 PM
03/12/21 04:25 PM
jcc
Bitopia
Its also about the time of day the meteor arrives, in that a daylight explosion is likely noticed visually by very few.
[Re: Hugh Jorgan]
#2898568
03/12/21 08:34 PM
03/12/21 08:34 PM
SattyNoCar
it WILL be an improvement.
Fixed. Thank you. I stand corrected.
John
[Re: Cab_Burge]
#2898618
03/12/21 11:34 PM
03/12/21 11:34 PM
Posts: 20,171 Park Forest, IL
slantzilla
Park Forest, IL
The Yellowstone Caldera will get us first.......
