Page 2 of 3 1 2 3
Re: New carbs, linkage and lines, everything fits [Re: an8sec70cuda] #2897336
03/09/21 11:08 AM
03/09/21 11:08 AM
MI
68shifter Offline
68shifter  Offline
MI
Looks great.
I’ve got a brand new set from Dale Cubic. If your ever at Martin it’d be an interesting comparison if you want to try them at some point.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: New carbs, linkage and lines, everything fits [Re: dvw] #2897341
03/09/21 11:44 AM
03/09/21 11:44 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looks great I am sure you will find your elusive 8 now.
Re: New carbs, linkage and lines, everythinnug fits [Re: DoubleD] #2897344
03/09/21 11:54 AM
03/09/21 11:54 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Yes for redundancy. Though all 4 shafts have springs. Fabbing up the parts like these.
Doug
Re: New carbs, linkage and lines, everything fits [Re: dvw] #2897368
03/09/21 01:16 PM
03/09/21 01:16 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Beautiful.
Rich H.
Esse Quam Videri
Re: New carbs, linkage and lines, everything fits [Re: ZIPPY] #2897658
03/10/21 10:31 AM
03/10/21 10:31 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Are those Main bodies cast or billet? It is hard to tell from the pictures.
I am bringing it up now so you dont end up in a pissing contest later.
Re: New carbs, linkage and lines, everything fits [Re: 66coronet] #2897683
03/10/21 11:37 AM
03/10/21 11:37 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If they are BLP BX4 main bodies they're billet.
Re: New carbs, linkage and lines, everything fits [Re: justinp61] #2897716
03/10/21 12:55 PM
03/10/21 12:55 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I think they are billet, why? What pissing contest?
Doug
Re: New carbs, linkage and lines, everything fits [Re: dvw] #2897721
03/10/21 01:03 PM
03/10/21 01:03 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
NMCA rules
CARBURETOR
(NSS CLASSES): All entries in the eliminator must be carbureted as outlined below. Positioning of carburetors from factory mounting not a tech item (carburetors may be positioned facing forwards, backwards, or side mounted). Choke horn, choke plate, choke shaft, choke linkage, and choke mechanism may be removed. Carburetors are restricted to the following manufactures: Holley, Edelbrock, Carter, Rochester, Demon, Quick Fuel Technologies. Vehicles in this class permitted the use of carburetors listed for NSS, or Holley, Quick Fuel or Holley based carburetor 4150 style with a maximum 1.750 throttle blade. (NO Dominators).
Carburetor must have commercially available cast main body. Billet Base Plate and metering blocks are permitted. All NSS combinations are permitted duel four carburetor setup.
FUEL
Re: New carbs, linkage and lines, everything fits [Re: nss guy] #2897775
03/10/21 03:31 PM
03/10/21 03:31 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I was just trying to keep you from getting to an event and tech bouncing you.
I am not saying I agree or disagree with the way the rule is written, but it is how it is written.
Re: New carbs, linkage and lines, everything fits [Re: 66coronet] #2897808
03/10/21 04:31 PM
03/10/21 04:31 PM
COLUMBUS, OH
W
Whompin_Wedge Online content
Whompin_Wedge  Online Content
W
COLUMBUS, OH
I was just going to wait until I had Doug in the finals to tell him they were illegal lol....
Honestly though... I think it is a silly rule. Don't see the advantage and most people wouldn't even be able to tell.
Thanks,
Casey FJ
Re: New carbs, linkage and lines, everything fits [Re: Whompin_Wedge] #2897831
03/10/21 05:49 PM
03/10/21 05:49 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
So does the manufacturer also come into play here? Must be produced by one listed?
Re: New carbs, linkage and lines, everything fits [Re: max_maniac] #2897855
03/10/21 06:48 PM
03/10/21 06:48 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Carbs lines and linkage all look top notch as usual for your stuff . What’s the new hood look like? whistling
Re: New carbs, linkage and lines, everything fits [Re: Whompin_Wedge] #2897968
03/10/21 10:37 PM
03/10/21 10:37 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
You could always come race with me???? Ignore the guy in background, he had too many Coors Lights.
Re: New carbs, linkage and lines, everything fits [Re: sjs64polara] #2898292
03/11/21 09:58 PM
03/11/21 09:58 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Doug looks awesome your stuff really is show quality. Are you using the` stuffers that indy sells? Also I don't see a pop off device. Having popped one of those intakes I highly recommend at least one. I had one on mine and it still popped the top off. Just trying to save you some aggravation and hood damage. If I ran another one of those intakes I would put a pop off on both sides.
Re: New carbs, linkage and lines, everything fits [Re: biff426] #2898337
03/12/21 07:23 AM
03/12/21 07:23 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Looks great Doug!
Re: New carbs, linkage and lines, everything fits [Re: ProSport] #2898347
03/12/21 08:52 AM
03/12/21 08:52 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am curious, how do the Indy cross rams compare to the big single plane intake, or a tunnel ram, which one makes more power?
Re: New carbs, linkage and lines, everything fits [Re: Dragula] #2898357
03/12/21 09:29 AM
03/12/21 09:29 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Could that be a spring loaded pop-off between the carbs?
Joe
Re: New carbs, linkage and lines, everything fits [Re: dvw] #2898374
03/12/21 10:59 AM
03/12/21 10:59 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
VERY well done, looks nice, I like that the shafts are splined , on my 8 stack linkage they are not & they have slipped once, so I had to loctite them.
Re: New carbs, linkage and lines, everything fits [Re: CSK] #2898431
03/12/21 01:06 PM
03/12/21 01:06 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
There is a pop off valve between the carbs. It popped once do to improper starting procedure. Never in 7 years since. There are no modifications to the intake. Power wise the Eddys with the crossram seemed very close. The closest motor to mine that I can think of was David Ross Charger. 572 from Best Engines with similar cam and compression. Dominator, 14x32 with a brake at I believe 3000lbs? 8.8x. Mine has been 9.00@3350
Doug
Re: New carbs, linkage and lines, everything fits [Re: CSK] #2898435
03/12/21 01:17 PM
03/12/21 01:17 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Looks good Doug!...you have any help? LOL I think the rules need revisiting. That rule may be written to maintain a 'nostalgic' appearance? There is no advantage using that body against the others available that are 'legal' when index racing. Based solely on 'nostalgic' appearance, your car fits that standard better than MOST that I have seen INCLUDING the appearance of the engine. Where would you draw the lines in that 'argument'? ...vacuum pumps, electric water pumps and fans aren't nostalgic but they are legal. Walk up to your car, and IT LOOKS NOSTALGIC! Pull the hood off, and IT LOOKS NOSTALGIC! Open your door, and IT LOOKS NOSTALGIC! Now if it had a sheet manifold, tin seats and Alumistars...not so much IMO. But those are legal?
Page 2 of 3 1 2 3
