transmission fluid additives #2894232
02/28/21 10:51 PM
02/28/21 10:51 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
racers , do you use any additives between rebuilds to help longevity? if so what do you like and why
Re: transmission fluid additives [Re: mcat4321] #2894360
03/01/21 12:39 PM
03/01/21 12:39 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I've used Lucas stop slip in my race 904. It's thick but the clutches and bands look good. I also use Lucas semi synth ATF in my 904. An additive isn't a cure all. In my other car with a glide I use ATI type F 20w with no additive. Also looks good inside
Re: transmission fluid additives [Re: mcat4321] #2894448
03/01/21 04:05 PM
03/01/21 04:05 PM
No additives for me in 727,904 or Powerglides down
Straight non synthetic ATF type F up
Re: transmission fluid additives [Re: Cab_Burge] #2894554
03/01/21 07:26 PM
03/01/21 07:26 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
And this stuff is getting hard to find in my area shruggy
Re: transmission fluid additives [Re: mcat4321] #2894580
03/01/21 09:28 PM
03/01/21 09:28 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
no additives , wallmart atf type f did my cuda trans in 1986 , still works perfeect !
30,000 miles and hudreds of drag passes .
no customer complaints !
Re: transmission fluid additives [Re: calrobb2000] #2894595
03/01/21 10:10 PM
03/01/21 10:10 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Tractor hydraulic fluid no additives
Re: transmission fluid additives [Re: racerx] #2894626
03/01/21 11:40 PM
03/01/21 11:40 PM
i have around 40 quarts in stock of Valvoline and Pennzoil non synthetic type F ATF fluid, I'll probably have to switch to ATI Synthetic ATF after all the old stuff is gone whiney
I currently have 3 gallons of the ATI synthetic ATF in stock, maybe do some fluid testing this year at the track with my bracket car work
Re: transmission fluid additives [Re: Cab_Burge] #2894806
03/02/21 02:03 PM
03/02/21 02:03 PM
moparx Offline
moparx  Offline
many, many [and many ! grin] years ago, one of the, at the time, big name transmission guru's said to add a quart of [10wt i think] detergent motor oil to the mix.
does anyone remember who this was, and what was the motor oil supposed to do ?
beer
Re: transmission fluid additives [Re: Cab_Burge] #2894900
03/02/21 04:48 PM
03/02/21 04:48 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Cab......ever tried the tractor fluid stuff? I thought about it years ago but didn't do it .if the need for transmission fluid get scarce might give it a try.
Re: transmission fluid additives [Re: moparx] #2894972
03/02/21 08:20 PM
03/02/21 08:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
beer
It was in Chrysler Power mag. I think it was called "Talking Torqueflites" shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: transmission fluid additives [Re: fourgearsavoy] #2894976
03/02/21 08:34 PM
03/02/21 08:34 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
i put a quart of 0w5 synthetic every time i change my fluid
Re: transmission fluid additives [Re: dbran451] #2895109
03/03/21 08:10 AM
03/03/21 08:10 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
CAT wet clutch hydraulic fluid.
I replace every 25 runs
Re: transmission fluid additives [Re: dbran451] #2895205
03/03/21 01:37 PM
03/03/21 01:37 PM
moparx Offline
moparx  Offline
what is this supposed to accomplish/do ?
TIA.
beer
Re: transmission fluid additives [Re: moparx] #2895278
03/03/21 04:27 PM
03/03/21 04:27 PM
PA
Harry's Taxi 2 Offline
PA
beer
I think it was Marv Booth? I have the Chrysler Power article somewhere. I'll try to remember to check tomorrow.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: transmission fluid additives [Re: FastmOp] #2896836
03/07/21 06:20 PM
03/07/21 06:20 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Fastmop.....is there a certain weight they use fir the transmission? I'm new to this fluid regular cheap type F is getting hard to find. realmad.
Re: transmission fluid additives [Re: fourgearsavoy] #2896865
03/07/21 08:23 PM
03/07/21 08:23 PM
Macon, Missouri
TJ2 Offline
TJ2  Offline
Macon, Missouri
beer
Gus beer
As I recall... in that "Talking Torqueflites" article by Marv Booth, he mentioned using straight 30w engine oil in place of using regular Dexron or Type F transmission fluid. Seems like he said you could use a quart or two as an additive... all the way to using ONLY 30w, with no regular transmission fluid. Seems like he claimed or spoke of using the 30w engine oil even in motor home/RV applications, saying that the thicker viscosity of the 30w even aided gas mileage a small bit in these heavy rigs.
If anyone happens to still have that issue/article available and handy, please fact check this for me... as my memory of this information may be off a bit... it has been quite a long time ago! work
