2011 Ram 1500 4X4 rear axle help #2896631
03/06/21 11:06 PM
03/06/21 11:06 PM
Way out in the sticks of Weste...
DusterDog Offline OP
Can anyone tell me what all would be involved to put a 2013 Ram 1500 4X4 rear axle into a 2011 1500??
I'm looking at buying a 2011 that was hit in the right rear, bent some sheet metal, & bumper, broke the tail light, & broke the axle off at the end of the housing.
The housing, & the lower control arm is bent as well. When I look at some of the local wrecking/salvage yards it seems that the 2011 model year is all by it's self as far as the axle.
I can get a complete (housing, control arms, & maybe the brake calipers) 9.25 from a local yard for a really good price.
"I've upped my horsepower, so...... UP YOURS!!!"
Re: 2011 Ram 1500 4X4 rear axle help [Re: DusterDog] #2896691
03/07/21 09:37 AM
03/07/21 09:37 AM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
I would check the frame,with that damage it could be bent also.
Re: 2011 Ram 1500 4X4 rear axle help [Re: GarageDodge] #2896707
03/07/21 10:46 AM
03/07/21 10:46 AM
I'm going to take another good look at it this week. It appears that it was an angled hit, body lines/gaps looked good at first. I couldn't see any bends, or kinks on the frame.
One of my co-workers says that Mopar changed the control arm design over the years, maybe made them heavier duty??
I'm thinking that if they made the control arms/bushings bigger, I "should" be able to drill the mounting brackets???
Re: 2011 Ram 1500 4X4 rear axle help [Re: DusterDog] #2896850
03/07/21 07:33 PM
03/07/21 07:33 PM
Guitar Jones Offline
Unless they are wider. I don't know, just something to consider.
Re: 2011 Ram 1500 4X4 rear axle help [Re: Guitar Jones] #2896861
03/07/21 08:10 PM
03/07/21 08:10 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
09-12 use the same control arm.
Re: 2011 Ram 1500 4X4 rear axle help [Re: DusterDog] #2897057
03/08/21 10:58 AM
03/08/21 10:58 AM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
At some point in the 2009-2014 timeframe they changed from the Corporate 9 1/4 axles to a ZF design that is completely different. It should be a bolt in but may require new driveshaft or control arms as well.
