Re: Led conversion 71 ebody
[Re: Mr D21]
#2895925
03/05/21 06:43 AM
03/05/21 06:43 AM
Posts: 5,647 Port Huron, Michigan
MI_Custumz
I used www.superbrightleds.com for all my stuff (1970 Monte Carlo) and their site is really easy to use. The only thing I didn't like from there was the electronic flasher. It worked good, but did not have the clicking noise for the blinkers. I used a plug in with a tail for a ground. It clicks, but also clicks like 1 or 2 more times after the blinker is off. Rather have the sound than not. All the dash lights were plug and play and didn't have issues with polarity sensitive like some others have said to have with LED. Headlights and blinkers in the dash are the only thing not LED. Forgot about the blinkers until I put it back together and will change them out next time I have the dash pad off.
[Re: A39Coronet]
#2896362
03/06/21 07:48 AM
03/06/21 07:48 AM
MI_Custumz
I also used Superbrightled.com for all my LED purchases this far on my 71' e body. I like that theyr un cooler, and don't tax the wiring or connections as bad. I'm not going LED for the headlights or front parking lights (clear lenses so you can see the bulbs), but everything else is getting them. I haven't done headlights yet either. I can't find one that is plug and play and doesn't look funny. I have a spear covering the tip of the front marker light in the Monte. It has a clear lens and amber bulb. Looks good and can only notice it's LED if you get up close enough and look at an angle. If it was an open lens to see the bulb, I would go with a regular bulb.
