Jones Racing crank pulley #2894960
03/02/21 07:28 PM
03/02/21 07:28 PM
Boise
Moparteacher Offline OP
Boise
Hola!
Do any fellow Moparites have personal pic(s) of the Jones Racing double v-groove crank pulley #CS-3102-CH? Any dimensions? Depth? Offset? etc? My understanding is it 's 5.2" in diameter, but I have little else except a crappy pic on their website.
Also, does anyone have a crank pulley to power steering pulley ratio calculator link? Is is calculated on minimum rpm or maximum rpm, or other?
Thanks,
Moparteacher
Re: Jones Racing crank pulley [Re: Moparteacher] #2894990
03/02/21 09:07 PM
03/02/21 09:07 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Give them a call, but expect to talk for a while, they won't you off the phone until they are sure they got it right.
Joe
Without Data, you’re just another guy with an opinion.
Re: Jones Racing crank pulley [Re: sr4440] #2895090
03/03/21 03:59 AM
03/03/21 03:59 AM
Boise
Boise
I called them today. They seemed very busy so I thought I would utilize additional sources of knowledge and experience prior to calling back. Thanks.
Re: Jones Racing crank pulley [Re: Moparteacher] #2895131
03/03/21 09:42 AM
03/03/21 09:42 AM
CJD AUTOMOTIVE Offline
Originally Posted by Moparteacher
Hola!Also, does anyone have a crank pulley to power steering pulley ratio calculator link? Is is calculated on minimum rpm or maximum rpm, or other?
Thanks,
Moparteacher
P/S is calculated on pump speed. Most pumps are cavitating at anything over 6000 rpm, so try and match your max engine RPM to turn the pump 6K.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
