915 Head Rebuild vs New Stealth Head
#2894282
03/01/21 07:53 AM
03/01/21 07:53 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
So.. time to figure out what head for my 67 440HP. Basically stock rebuild and the car is going to be a driver not a track car. 480ish cam, 2355 pistons, holley SD intake, HP manifolds. I would like the stock straight spark plug configuration which makes me lean toward stealth heads but I have heard you should take your new stealth heads to a machine shop and have them go over everything. So basically your $1000 plus shipping stealth heads probably will cost you $1500 when you are done, yes? So would rebuilding my 1.74 valve 915HP heads with exhaust seats be cheaper and give the same performance? What would you do? Thanks.
RS23L7 4-Speed
Re: 915 Head Rebuild vs New Stealth Head
[Re: Mopar_Mike]
#2894292
03/01/21 08:47 AM
03/01/21 08:47 AM
Posts: 1,776 Keymar, MD
DusterKid
Keymar, MD
I bought a set of stealth heads and put them on my race car back in 2008/09. I took them out of the box and bolted them on. My engine is a mild race engine compared to most, was 10:1 with a .533 mopar cam. I later put a .557 solid cam in and changed the valve locks from 7 degree to the 10 degree ones. I ran the heads for 5 years before having someone do some hand porting on them (didn't make a different in my combo). I did end up putting new valve springs on then as well since I had 2 or 3 broken inner springs I shifted the engine at 6000, would go thru the traps at 6500. Most will tell you to have things checked over, but for a street car, I wouldn't have a problem just bolting them right on, but that's just me. If you have to buy new valves and springs for your steel heads, I'd think your going to have just as much in them as the alum heads.
[Re: Mopar_Mike]
#2894321
03/01/21 10:44 AM
03/01/21 10:44 AM
Posts: 4,785 Holland MI Ottawa
2boltmain
Holland MI Ottawa
My opinion- If a closed chamber OEM head will make the power you want AND if the cost to refurbish them comes in at say $900 then go this route. Its recommended that every aftermarket head whether its an el cheapo whatever all the way up to big time $$ great brand heads that you pay to have a shop completely check them out and correct everything. For $900 to have your heads redone you know they correct and ready at time of pick up.
Keep old mopars alive.
[Re: Mopar_Mike]
#2894324
03/01/21 10:54 AM
03/01/21 10:54 AM
Posts: 1,487 STL
cdstl
STL
So.. time to figure out what head for my 67 440HP. Basically stock rebuild and the car is going to be a driver not a track car. 480ish cam, 2355 pistons, holley SD intake, HP manifolds. I would like the stock straight spark plug configuration which makes me lean toward stealth heads but I have heard you should take your new stealth heads to a machine shop and have them go over everything. So basically your $1000 plus shipping stealth heads probably will cost you $1500 when you are done, yes? So would rebuilding my 1.74 valve 915HP heads with exhaust seats be cheaper and give the same performance? What would you do? Thanks. I bought a set of Stealths to improve the flow and avoid replacing the seats, springs and valve guides on a set of 1965 615 heads. The intake seat on the Stealth heads is small and it will require a valve job to it up and get close to the advertised 290 CFM flow out of the box. The valve guides and springs worked with my application but the spring seats were "too thick" for the spring compressed height with a fairly mild cam. I ended up paying for the valve job and different spring seats, so yes, you can expect to spend around $1500 to have a set of decent flowing heads for your application. I figured that a valve job, seats, bronze guides and certainly springs would have run about $850. With my cam I flow around 270 CFM vs 210 CFM with the 516s. My 383 (390, .040 over) made 480hp/460tq with an Eddy 1407 carb, Performer 383 intake and 2" dyno headers with around 10:1 compression. It could have been richened up some and would probably have made a little more. Certainly more with a better carb and intake. Cam is a custom Bullet .485/.490, .227/.234 at .050. Those heads make a difference and yes I would do it again. Here's a link to the flow sheet. 440 Source flow after a valve job
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: cdstl]
#2894333
03/01/21 11:18 AM
03/01/21 11:18 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The Stealths certainly don’t need $500 worth of labor done to them to be run. For around $550 you could have a proper valve job done, back cut valves, skim cut the decks....... and have the bowls blended and a flow test done. But they certainly don’t “need” all that be done to them.
The ootb flow is nowhere near 290. It’s high 250’s/low 260’s. After recutting the seats and blending the bowls it’s about 280.
If someone wanted to run them ootb, I wouldn’t argue too hard against that.
At my shop, it’s unlikely you’d be able to have a set of 915’s gone through completely, all new parts, hardened ex seats, all new guides, valve job, flat mill, etc, for any less than what you’d have in the Stealths.
[Re: cdstl]
#2894663
03/02/21 07:36 AM
03/02/21 07:36 AM
2boltmain
Holland MI Ottawa
I see as of 3-2-2021 the Stealth heads are $1000 per pair. I didn't realize they could be purchased at so low a price. However- in the rare event those 54 year old 915 castings need MINIMAL work to be ready to run they are still an option but my mind is shifting toward the Stealths.
[Re: fastmark]
#2894674
03/02/21 08:36 AM
03/02/21 08:36 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
A wonderful question to ask after 50 years of iron heads! 915 67 big valve heads are top of the 440 tree in my mind. 906’s are very over rated and 452’s are better... But it’s 2021 and aluminium is king now! Better ports, less weight and affordable. Me I would spend 100 hours porting each 915 head and be very, very happy to do so... Do I need hardened seats, not for the 1/4 miles I do lol... Do they need a skim every time I take them off? Not really... Had a pair of 452 MP aluminium heads to repair and they were Awful. One head was bowed 0.020 thou that’s 0.5mm... The work needed to put it right was crazy...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: 73DAD]
#2894751
03/02/21 11:43 AM
03/02/21 11:43 AM
fast68plymouth
So. Burlington, Vt.
While I don’t really have anything against the Stealth heads, I like to buy American if possible.
There is only a $149 price difference between the Stealths and some E streets, and the E streets ship for free.
The stock look of the Stealth is worth zero to me......... so the E streets are what I’d use(and they flow better ootb).
[Re: Gtxxjon]
#2894752
03/02/21 11:44 AM
03/02/21 11:44 AM
Posts: 4,695 Wichita
GY3
Wichita
Had a pair of 452 MP aluminium heads to repair and they were Awful. One head was bowed 0.020 thou that’s 0.5mm... The work needed to put it right was crazy... Funny, these are the Edelbrock Performer RPM's (save for straight spark plugs) that everyone raves about being so good and "Made in U.S.A!"
[Re: Mopar_Mike]
#2895100
03/03/21 06:53 AM
03/03/21 06:53 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I'll follow along. I only have used the old Stealth heads on the 1969 Coronet 505" stroker engine, I bought those along time ago, so I have no idea how they compare to the current castings? My castings were nice quality, but I never run heads out of the box. Needed to change springs and retainers for the hydraulic roller cam, so also did some mild porting and valve job while they were apart. Didn't need to surface my heads?
Originally, I wanted to use them for the more stock look, with manifolds, but I kept making changes to the engine with headers, EFI and such, so now the "original" look is a non-factor, and I though about going with a head with better spark plug placement (in the chamber.)
I haven't used the Edelbrock E-Street heads, but they look decent on paper, and have a slightly smaller chamber volume for more compression.
The aluminum heads use reduced wrenching head bolts, so figure the bolt hardware into the cost of the aluminum heads.
The 915's could be re-built at less cost, and you could re-use the original head bolts. For the $1,000 cost of the aluminum heads, you could put the larger stainless valves in, and hardened exhaust seats in the 915's, and maybe even some mild porting?
Anyhow, if you want more originality or lower cost, I would likely rebuild the 915's with the larger valves and some porting.
If you want performance, the aluminum heads might be a better starting point?
[Re: bobby66]
#2895152
03/03/21 10:43 AM
03/03/21 10:43 AM
fast68plymouth
So. Burlington, Vt.
Aren't the E-street heads and overseas casting assembled in the USA? They are the same exact castings as the RPM heads. Cast at the Edelbrock foundry in California. I wonder if all the 915 proponents use the same line of thinking with other items in their lives. Like daily driver cars that are 50 years old, music in the home on an 8 track player, old black and white tv with rabbit ears, rotary dial telephones, etc.
[Re: fast68plymouth]
#2895172
03/03/21 12:02 PM
03/03/21 12:02 PM
Posts: 315 Northeast Indiana
73DAD
Northeast Indiana
Aren't the E-street heads and overseas casting assembled in the USA? They are the same exact castings as the RPM heads. Cast at the Edelbrock foundry in California. I wonder if all the 915 proponents use the same line of thinking with other items in their lives. Like daily driver cars that are 50 years old, music in the home on an 8 track player, old black and white tv with rabbit ears, rotary dial telephones, etc. classic false equivalence fallacy
[Re: 73DAD]
#2895192
03/03/21 01:10 PM
03/03/21 01:10 PM
fast68plymouth
So. Burlington, Vt.
Perhaps....... if you care to interpret it that way.
The point was, as things wear out...... the owners are presented with a choice. Repair it, or replace it. Whether it’s a furnace, a refrigerator, washing machine, computer, a vehicle ...... or parts for your car.
There is a whole industry that exists because there are enough people who elect to replace their cylinder heads with new and improved pieces instead of refurbishing their old ones.
#2895206
03/03/21 01:38 PM
03/03/21 01:38 PM
Posts: 10,750 North Dakota
6PakBee
North Dakota
If a technological advance befits the user, it is worth considering. If it doesn't benefit the user, why go there? I know a lot of people who still have a flip phone because it does everything that they need it to do. If a cast iron head does everything the owner wants, why spend money on something else? One example I think of are the newer refrigerators that have the see through door. Really? Now we are too lazy to open the door? And paid a premium for not having to open the door.
[Re: 6PakBee]
#2895261
03/03/21 03:30 PM
03/03/21 03:30 PM
Posts: 3,238 Md.
carnut68
Md.
The way I see it is your butt dyno will never tell the difference between the two heads. If doesn't go to the track you'll never know the power difference. Do what you can afford.
America First!
