Can’t get the damn thing to start because I installed a fresh new battery in the dark without getting the polarized post hooked up correctly and I fried the fused link and had to reroute power to the ignition wire through the dash instead of the firewall block connector. I had a newborn 6ALMSD box And a new blaster coil installed as a upgrade but I am not getting a feed through the trigger signal on the box. Everything else in the car electrical seems to be working. Have I fried the ammeter or what other suggestions but you have for me to work next. I’m running out of time and pop
So if I am reading this correctly the MSD and coil were installed after the event.
Regardless, with the dedicated + and - MSD wires attached and the switched 12 volt wire powered up there is a procedure in the installation manual to test for spark.
Have you tried that ? That bypasses the distributor. If it fires look at the distributor next.
