proper quench with 452 heads #289383
04/15/09 07:38 PM
04/15/09 07:38 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
how would one get the proper and keep the compression around 9.5:1.what style pistons would be used,dome flat top or other. thanks
Re: proper quench with 452 heads [Re: Ken25] #289384
04/15/09 07:46 PM
04/15/09 07:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
step dome piston , like a KB , but what KB has will not get you that compression ratio easily once you equalize the chambetrs , it's going to take a CUSTOM piston , I'm having them made for a build I'm doing using 452's..
Re: proper quench with 452 heads [Re: JohnRR] #289385
04/15/09 07:51 PM
04/15/09 07:51 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
just currious how high can you get the compression with out decking the block.
Re: proper quench with 452 heads [Re: JohnRR] #289386
04/15/09 07:51 PM
04/15/09 07:51 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the kb184 will get you very close to 9.5. i have two engines with kb184's. one has 9.4:1 and the other 9.3:1 (these were checked by cc'ing heads and checking downfill). '452 heads usually have one deep chamber. after equalizing and milling 9.5:1 shouldn't be difficult to reach.
Re: proper quench with 452 heads [Re: lewtot184] #289387
04/15/09 07:56 PM
04/15/09 07:56 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
o.k i have 440 h.p. pistons stock bore 452 heads with the shim gassket. what ratio would i have?
Re: proper quench with 452 heads [Re: Ken25] #289388
04/15/09 08:01 PM
04/15/09 08:01 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
an hp piston could be anywhere from 9.5 to 10.5 with 88cc heads and steel shim gasket. measure the deck heigth and do some math. there are some piston variables.
Re: proper quench with 452 heads [Re: lewtot184] #289389
04/15/09 08:05 PM
04/15/09 08:05 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
how do you calculate the cr?how does that compare to psi?
Re: proper quench with 452 heads [Re: lewtot184] #289390
04/15/09 08:33 PM
04/15/09 08:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That piston won't work for me , I had 2 deep chambers , to use that piston I'd have to cut about .060 off the heads using a steel shim gasket and still end up with the major part of the piston .090 in the hole, with a large valve relief which really isn't needed .
Re: proper quench with 452 heads [Re: Ken25] #289391
04/15/09 09:10 PM
04/15/09 09:10 PM
http://kb-silvolite.com/calc.php?
