Freighter throws rods and destroys engine compartment #2893496
02/26/21 07:48 PM
02/26/21 07:48 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Master, again and still
Re: Freighter throws rods and destroys engine compartment [Re: DaveRS23] #2893501
02/26/21 08:00 PM
02/26/21 08:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Nice job on the engine rebuild...
Just cut on the rods to get the bushings in, eh ?
Re: Freighter throws rods and destroys engine compartment [Re: topside] #2893513
02/26/21 08:52 PM
02/26/21 08:52 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Maybe a phord mechanic doing the rebuild?
Re: Freighter throws rods and destroys engine compartment [Re: DaveRS23] #2893524
02/26/21 09:36 PM
02/26/21 09:36 PM
A727Tflite Offline
A727Tflite  Offline
I’m sure some of you recall seeing the locomotive that launched piston after the jug came loose from the crankcase.
2BA413EC-8B03-4D58-A308-C0CF64274F66.jpeg9FA9332C-528E-4EEA-AF94-21F529CB38C2.jpegACAAC5E9-FD37-4328-AA60-A76D49AA86FD.jpeg3BB5DC0C-6069-4632-AF6E-F6D71EF93387.jpeg
Re: Freighter throws rods and destroys engine compartment [Re: DaveRS23] #2893526
02/26/21 09:38 PM
02/26/21 09:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
My father was a engineer and later got his Chief engineer license for medium ship diesel engines, those engines are HUGE shock
Very low speed RPM wise also, maybe 1200 RPM max, maybe less or a little bit higher confused
Re: Freighter throws rods and destroys engine compartment [Re: Cab_Burge] #2893541
02/26/21 10:38 PM
02/26/21 10:38 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Cutting to the chase, in the little things do matter column:
""The introduction of notches, probably caused during the bush removal process, introduced stress [risers] into the small end, increased the likelihood of fatigue crack initiation and therefore fatigue failure."
Referring to the Con rod rebushing screw up by a hand angle grinder that was likely the cited cause of the calamity.
Re: Freighter throws rods and destroys engine compartment [Re: jcc] #2893549
02/26/21 11:08 PM
02/26/21 11:08 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Yikes.
Hopefully that rebuilder doesn't offer Mopar crate engines.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Freighter throws rods and destroys engine compartment [Re: DynoDave] #2893576
02/27/21 01:01 AM
02/27/21 01:01 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Should of had a man standing beside that mess t show the size of engine
Re: Freighter throws rods and destroys engine compartment [Re: cudaman1969] #2893586
02/27/21 02:50 AM
02/27/21 02:50 AM
I think all the large ship diesel engines have removeable inspection plates into the crankcase large enough for a man to walk into and have to look up to see the wrist pins shock
The comment about a man standing beside one is a good example of the large sizes up bow
Re: Freighter throws rods and destroys engine compartment [Re: DaveRS23] #2893599
02/27/21 07:00 AM
02/27/21 07:00 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Strictly from a business viewpoint
the small sum of money saved by having a cheap rate crew overhaul the engine
is far less than the $ damage.
Years ago I needed an EMD diesel rebuilt out of a GP-38 locomotive.
We got bids from several shops, one of which located near New Orleans did mainly ship service diesels.
This shop sent one of the owners to “sell us” on why his business should get the job.
One of his arguments was:
“Our marine customers hold us to much higher standards than railroad customers because if an engine goes bad at sea it is much more of a life or death situation.”
We gave that engine rebuilding shop the job and they delivered an engine that performed well and very noticeably leaked less oil than even factory new GM EMD engines did.
Re: Freighter throws rods and destroys engine compartment [Re: DynoDave] #2893624
02/27/21 09:46 AM
02/27/21 09:46 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by DynoDave
Yikes.
They probably torqued by feel, because experience you know.
Re: Freighter throws rods and destroys engine compartment [Re: Cab_Burge] #2893634
02/27/21 10:54 AM
02/27/21 10:54 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
In the marine world, that is considered a high speed diesel.
The big ocean going units are slow speed, in the 80-120 RPM range.
Kevin
Re: Freighter throws rods and destroys engine compartment [Re: Twostick] #2893643
02/27/21 11:18 AM
02/27/21 11:18 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The utility I worked at had a number of '40's era diesel generating plants. Rating was about 2.4 MW per unit IIRC. The plant manager started one up for us on a visit and it was chugging along at about 800 rpm and I asked him when he would take it off idle. He looked at me funny and said that it was already at governed speed.
Re: Freighter throws rods and destroys engine compartment [Re: Twostick] #2893648
02/27/21 11:26 AM
02/27/21 11:26 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
The engine in this ship from what I can gather, is a MAN 12V 48/60 .
A medium speed diesel. Just over 19,000 HP @ 500 RPM. shock panic
Torque at peak HP is just over 199,000 ft/lbs. Not sure what peak torque is but I suspect it's approaching the outer limits of a 727 Torqueflite . biggrin
Kevin
Re: Freighter throws rods and destroys engine compartment [Re: Twostick] #2893660
02/27/21 11:38 AM
02/27/21 11:38 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
delete
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Freighter throws rods and destroys engine compartment [Re: DaveRS23] #2893678
02/27/21 12:16 PM
02/27/21 12:16 PM
IMGTX Offline
IMGTX  Offline
Given the size of that engine. If they can't take the block out in pieces I can't see a way to fix it that would be cheaper than a new boat.
Even if you can remove the block in pieces I think your gonna have a big, big, problems getting pieces that size out of the hull.
I don't know but it seems like they totaled a ship. shruggy
Re: Freighter throws rods and destroys engine compartment [Re: IMGTX] #2893698
02/27/21 01:11 PM
02/27/21 01:11 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not at all, cut out the deck(s) above, hoist it out, put new one in, weld decks back in. Not uncommon in ship repair.
Re: Freighter throws rods and destroys engine compartment [Re: IMGTX] #2893699
02/27/21 01:12 PM
02/27/21 01:12 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
They won't total a ship that size. They'll cut a hole in the side and out it goes. Saw them do that in a documentary on TV one time. Crazy amount of work/time/money but that's what they do. Here they are doing a cruise ship in the same manner:
https://www.youtube.com/watch?v=pw6-82YVIbE
Re: Freighter throws rods and destroys engine compartment [Re: IMGTX] #2893732
02/27/21 02:35 PM
02/27/21 02:35 PM
IMGTX Offline
IMGTX  Offline
Wow I guess if there is a will or a paycheck there is a way.
That just seems like a crazy repair. up
Re: Freighter throws rods and destroys engine compartment [Re: IMGTX] #2893740
02/27/21 02:54 PM
02/27/21 02:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Of course anything is doable, but there are of course many other factors involved in deciding what is the best solution/repair, like age of the hull, cost of a replacement engine, market that the ship serves, overall environmental footprint of the ship in regards to current or future expected regulations, its cost to operate relative to the competition, and the depth of the pockets of the owner or who ever foots the bill, and lastly, how close is the ship to Bangladesh grin https://en.wikipedia.org/wiki/Ship_breaking
