Rear Axle width guide/reference #2892872
02/24/21 10:38 PM
02/24/21 10:38 PM
Massachusetts
Faust Online content OP
Faust  Online Content OP
Massachusetts
I have decided the easiest way to get "highway gears" in my 37 Packard, without real surgery, is to replace the rear axle. Can anyone point me to a reference for rear axle widths?
Re: Rear Axle width guide/reference [Re: Faust] #2892873
02/24/21 10:41 PM
02/24/21 10:41 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The axle dimension reference section on here is bust according to some comments over the years....
Re: Rear Axle width guide/reference [Re: Faust] #2892993
02/25/21 11:39 AM
02/25/21 11:39 AM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
Re: Rear Axle width guide/reference [Re: Neil] #2893021
02/25/21 01:20 PM
02/25/21 01:20 PM
CA
crackedback Offline
crackedback  Offline
CA
The garbage chart was finally removed.
Re: Rear Axle width guide/reference [Re: crackedback] #2893175
02/25/21 08:35 PM
02/25/21 08:35 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
It is unfortunate that most rear end width charts these days want to show the track width. That isn't very helpful unless you know the wheel width and offset.
You need to know what your width is before you can get one close. Bolt patterns are the next challenge. Finding a solid axle assembly in a pull a part will be the next challenge. Most of the stuff at pull a parts is less then 10 years old.
For what its worth:
S10 are about the most narrow axles.
Early Dakota (pre 91 are 5 bolt, 91 & up are 6 bolt), and Jeep will be the next narrowest.
Ford Explorers are next (and about the best buy)
Then it goes to the late model trucks.
Lots of off shores axle widths in between. Good luck! Gene
