Right Side Brake Lights Stopped Working #2892528
02/24/21 12:37 AM
02/24/21 12:37 AM
South San Francisco, Ca
70sixpkrt Offline OP
I recently had my car in the body shop, for the last 4 months, due to some idiot damaging it. Long story. I had to get the whole car painted. The body shop took off the rear tail light housing, bumper, etc. I picked the car up today and drove it home and now the brake lights on the right side don't work. The left side works and the tail lights on both sides work. It's just the right brake lights. Is there a ground wire on the right side? And where would it be? The steering wheel was never pulled.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Right Side Brake Lights Stopped Working [Re: 70sixpkrt] #2892543
02/24/21 02:26 AM
02/24/21 02:26 AM
Cab_Burge Online work
Cab_Burge  Online Work
I would check the right side housing to see if it is grounded, I think it may have a built in ground spade on it for a ground wire to connect to scope
Re: Right Side Brake Lights Stopped Working [Re: Cab_Burge] #2892546
02/24/21 02:49 AM
02/24/21 02:49 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
iagree
How bad was the damage?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Right Side Brake Lights Stopped Working [Re: BloFish] #2892575
02/24/21 09:02 AM
02/24/21 09:02 AM
Andrewh Offline
Andrewh  Offline
Usually it is grounded by the screws going through the housing to the body.
Fresh paint will insulate the whole thing. Most times you have to chase the hole with something to get the paint out. Running the screw in and out a few times usually works, but not 100 percent.
Re: Right Side Brake Lights Stopped Working [Re: Andrewh] #2892611
02/24/21 10:37 AM
02/24/21 10:37 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If the tail light works its probally not a ground problem Check the bulb to be sure its good and installed the correct way they can be put in backwards and that its the correct bulb Thats the easiest Then get a test ligt apply brake and see if it has power Same with turn signal.Should have power with both.Rocky
Chrysler Firepower
Re: Right Side Brake Lights Stopped Working [Re: BloFish] #2892613
02/24/21 10:46 AM
02/24/21 10:46 AM
Originally Posted by BloFish
iagree
Dent in the left quarter panel and deep scratches on the right quarter panel. I went to 10 good body shops and nobody would touch it because it was going to open a can of worms. My neighbor suggested the place that restored his 69 charger and I brought it there. I will check everything today. It's hard to apply the brakes and then look since nobody is home (working) and I'm by myself.
4-speed
3:54 Dana
Re: Right Side Brake Lights Stopped Working [Re: 70sixpkrt] #2892620
02/24/21 11:06 AM
02/24/21 11:06 AM
Andrewh Offline
Andrewh  Offline
loosen the brake light switch and you don't need to touch the brakes.
Re: Right Side Brake Lights Stopped Working [Re: Andrewh] #2892633
02/24/21 11:39 AM
02/24/21 11:39 AM
Parking lights work on both sides, trunk light works, blinkers work on both side, license plate works, reverse light works. Brake light only works on left side. Funny thing is I keep getting dead battery and it's a new battery.
4-speed
3:54 Dana
Re: Right Side Brake Lights Stopped Working [Re: 70sixpkrt] #2892637
02/24/21 11:44 AM
02/24/21 11:44 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Still check the ground . . . always weird things happen with bad ground . . . on the Satellite I put additional grounds on the freshly painted car, and had no issues . . . good luck . . oh, and check the connector for the rear harness ??? Make sure you are getting power to wires going to right side brake light circuit ???
Re: Right Side Brake Lights Stopped Working [Re: 70sixpkrt] #2892639
02/24/21 11:46 AM
02/24/21 11:46 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Well, the bulbs sound just fine. How about climbing in the car, have a spotter watch the lights while you work the turn sig lever from right to left while on brake pedal. Chances are the lights may momentarily light, indicating that turn sig switch is toast.
Re: Right Side Brake Lights Stopped Working [Re: buildanother] #2892642
02/24/21 11:51 AM
02/24/21 11:51 AM
What would cause the dead battery. Brand new. I drove it home about 30 miles, amp gauge was good. Pulled the battery cables off for over night. This morning dead battery. Is this coincidence or part of the right brake light not working?
4-speed
3:54 Dana
Re: Right Side Brake Lights Stopped Working [Re: 70sixpkrt] #2892643
02/24/21 11:54 AM
02/24/21 11:54 AM
BDW Offline
BDW  Offline
Re: Right Side Brake Lights Stopped Working [Re: BDW] #2892645
02/24/21 12:04 PM
02/24/21 12:04 PM
Good article. I will try that later. Thank you. The body shop had to get me a battery since it was going dead.
4-speed
3:54 Dana
Re: Right Side Brake Lights Stopped Working [Re: 70sixpkrt] #2892666
02/24/21 12:59 PM
02/24/21 12:59 PM
Well I went under the dash to look at the turn signal connectors. I noticed that the Pink wire going to the brake switch was not fully connected. I connected it and it looks like my right brake light is working now. luck Now to deal with the dead battery issue. My Volt meter broke last year so I guess I have to get a new one. I'm wondering if my Alternator took a dump.
4-speed
3:54 Dana
Re: Right Side Brake Lights Stopped Working [Re: 70sixpkrt] #2892739
02/24/21 03:32 PM
02/24/21 03:32 PM
The battery is bad, it should not loose it charge overnight when it is disconnected shruggy
I would get the old one back and have the body shop give you back the money they charged you for the defective battery twocents
Re: Right Side Brake Lights Stopped Working [Re: Cab_Burge] #2892883
02/24/21 10:58 PM
02/24/21 10:58 PM
when the pink wire was not making contact at the pedal switch both brake lights would have been non op. You may have jostled another connector when you were under there that restored contact. Keep an eye on it. for a start I would pull apart then reconnect all the connectors under there related to the TS harness
Re: Right Side Brake Lights Stopped Working [Re: RapidRobert] #2892888
02/24/21 11:07 PM
02/24/21 11:07 PM
Good idea. up Thanks
4-speed
3:54 Dana
Re: Right Side Brake Lights Stopped Working [Re: 70sixpkrt] #2893074
02/25/21 03:54 PM
02/25/21 03:54 PM
moparx Offline
moparx  Offline
look close at the connection on the steering column where the turn signal switch connects to the body harness.
that connection can cause all sorts of problems. look for loose or broken/cracked terminals as well as for signs of melting of the plastic connecting blocks caused by high resistance [loose or corroded] of the terminals.
beer
Re: Right Side Brake Lights Stopped Working [Re: moparx] #2893091
02/25/21 04:39 PM
02/25/21 04:39 PM
beer
Will do. Thanks.
4-speed
3:54 Dana
