Inside car battery shut off #2892410
02/23/21 07:15 PM
02/23/21 07:15 PM
Minnesota, USA
humpty Offline OP
humpty  Offline OP
Minnesota, USA
What options are available for adding an inside the car battery shut off you can access from the driver's seat?
Thanks in advance!
Re: Inside car battery shut off [Re: humpty] #2892433
02/23/21 07:42 PM
02/23/21 07:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
If I ever do mine I'll just run a morse cable from a lever somewhere near the shifter to the disconnect switch in the trunk.
Re: Inside car battery shut off [Re: justinp61] #2892441
02/23/21 07:50 PM
02/23/21 07:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
This. One switch, operated from the rear or the drivers seat. Legal, safer, more convenient.
Two switches just doubles the chances of forgetting to turn it on or off. And the rulebook says the switch must be mounted at the rear of the car. Closer to the battery, the better.
Re: Inside car battery shut off [Re: CMcAllister] #2892447
02/23/21 07:58 PM
02/23/21 07:58 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Only time I've seen in car battery shut offs is in scca road race cars and other forms of road racing. Even the Lemons race cars have to have inside shut off. Drag race tail of car exterior.
Re: Inside car battery shut off [Re: humpty] #2892449
02/23/21 07:59 PM
02/23/21 07:59 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
why do you need a switch near the driver seat ?
trunk mount battery must have a external switch knob on drag cars .
Re: Inside car battery shut off [Re: calrobb2000] #2892454
02/23/21 08:18 PM
02/23/21 08:18 PM
Suffolk,VA
dragracedr Offline
dragracedr  Offline
Suffolk,VA
Originally Posted by calrobb2000
hi
one frequently gets in the car, buckles in, and forgets to to trip the outside switch. Also the emergency crews at some tracks are a little "slow". Turning off the power b the driver can obviate further vehicle damage. Heck, at some dragstrips you have to back into the water box. On occasion I've backed into the splash guard behind the water box, hit the push shutoff at the rear of the car against the splash shield, and shut the car off. Embarrassing.
Re: Inside car battery shut off [Re: humpty] #2892455
02/23/21 08:19 PM
02/23/21 08:19 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Do you really want a length of 00 welding cable carrying 100 amps next to you?
If a crash pierces the insulation, you may become the ground cable.
Safer:
12 gauge switch leads out of cabin to a big relay near the battery which carries the actual current.
Boffin Emeritus
Re: Inside car battery shut off [Re: polyspheric] #2892460
02/23/21 08:44 PM
02/23/21 08:44 PM
Minnesota, USA
humpty Offline OP
humpty  Offline OP
Minnesota, USA
The idea is one switch at the rear near the battery and two ways to actuate it. One from the rear and one from the driver's seat. I like the morse push/pull cable idea. If anyone has examples they can share I would appreciate it.
Re: Inside car battery shut off [Re: humpty] #2892496
02/23/21 10:38 PM
02/23/21 10:38 PM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
I designed a setup with a Morse cable with a chute handle to actuate the lever on the switch. Still had the Push (off) Pull On handle that went out the trunk. Never installed, sold the car, but still have the parts. May put it on the Road Runner
I think Lokar makes a kit.
Yes, i have buckled in and had to get out to flip the switch.On. At laest it was in the pits, not in staging LOL.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
Re: Inside car battery shut off [Re: humpty] #2892518
02/23/21 11:55 PM
02/23/21 11:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
This. Battery cable should be run inside anyway, but that's another conversation. No need to touch the existing wiring or switch. A lever, probably overhead, similar to a chute handle, with a morse cable to the switch and piggie backed onto the lever going out the back.
A switch mounted through a body panel with the knob on the outside may present an issue, but most people put the switch inside with a push/pull rod these days.
Not only is it a convenience thing to keep from having to get out of the car if you forgot to turn it on, It's a safety thing as well being able to get it all shut off while still in the car. Throttle stuck open, fuel fire, electrical issue. I'll never have a car without it.
Re: Inside car battery shut off [Re: CMcAllister] #2892529
02/24/21 12:47 AM
02/24/21 12:47 AM
montana
BANDIT Offline
BANDIT  Offline
montana
When I bought my Avenger, the previous owner had put a switch on both battery cables, activated by 1 lever thru rear panel. I simply got a Lokar lever and cable set up, hooked it to one switch, and mounted lever on passenger side floor. As was said earlier, I had been buckled in numerous times before I realized the switch was off. One of my better upgrades. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Inside car battery shut off [Re: BANDIT] #2892544
02/24/21 02:31 AM
02/24/21 02:31 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm starting to feel like a broken record, advocating for a lithium battery. But you eliminate so much weight and wiring. Here's what I did. I mounted a four and a half pound lithium battery, 780 cranking amps, under the floor between the driver's seat and the starter. Then I used a regular cutoff switch from summit racing with a shaft and a lever. I mounted that under the floor with the shaft oriented vertically protruding up through the floor below the area between the drivers knees, with the lever pointed to the side. Then I wired the battery to the switch, and to the starter and all the other stuff. Now I have a switch that I can shut on and off while I'm sitting in the car. To operate the switch from the rear of the vehicle, instead of a heavy and expensive Morse Cable, I used a length of 5/16 inch OD by 035-in wall 304 stainless tubing. I put a spherical rod end on it and a bolt through that into the lever on the switch. The stainless tubing extends out the rear of the vehicle. It has a few bends in it to clear obstacles. And a t-handle welded on the end outside under the deck lid. The whole setup is very light, very functional, and very reliable.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Inside car battery shut off [Re: Hemi_Joel] #2892552
02/24/21 06:11 AM
02/24/21 06:11 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used a Morse cable. The rear pivot is some scrap steel and a piece of 3/8" steel tube. The tube is held onto the switch with a 3/8" compression fitting cut in half. The upper lever was made from scrap 1/8" aluminum.
Doug
Re: Inside car battery shut off [Re: dvw] #2892570
02/24/21 08:25 AM
02/24/21 08:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
There is more and more people offering solid state relays that can carry the load of the whole car. Then it is just a simple toggle switch to make them work. I have seen the legality of them come into question though because they are not mechanical.
68 Barracuda Formula S 340
Re: Inside car battery shut off [Re: Hemi_Joel] #2892578
02/24/21 09:18 AM
02/24/21 09:18 AM
Minnesota, USA
humpty Offline OP
humpty  Offline OP
Minnesota, USA
I am going lithium as well but plan to leave it in the trunk for now. Part of wanting to do this is because of the new battery. Thanks for the input everyone!
Re: Inside car battery shut off [Re: humpty] #2892587
02/24/21 09:35 AM
02/24/21 09:35 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My Digital Delay switch panel has a lighted halo around the start button showing the switch is on.... I’m going to like that feature
Re: Inside car battery shut off [Re: J_BODY] #2892622
02/24/21 11:11 AM
02/24/21 11:11 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Lokar makes interior battery cut off switch kits with all the needed parts to attach to most shifters. They are not cheap at I believe 225-250 but has all the pieces to attach it to your shifter.
Re: Inside car battery shut off [Re: Al_Alguire] #2892644
02/24/21 11:57 AM
02/24/21 11:57 AM
Texas
Chief Offline
Chief  Offline
Texas
https://www.summitracing.com/parts/lok-1330013 Pretty expensive for something so simple..
I built mine.
Dave Covey
Re: Inside car battery shut off [Re: Bad340fish] #2892646
02/24/21 12:06 PM
02/24/21 12:06 PM
Texas
Chief Offline
Chief  Offline
Texas
I do chassis certification for IHRA and was one of the tech guy's for 13+ years. When builders started using the toggle switch controlled relays I questioned their use. The rule book says the battery cut off has to shut all current off.
My question was how a switch which uses 12 (?) volts to activate was legal. I later learned that they are supposed to be using a toggle to control the ground side of the relay.
Afterwards I started checking if it was negative or positive controlled.
And yes I was an A** at first. Now I see them with a push/pulll switch on the outside of the cars.
As a racer I like them because they are cleaner to install and you can put one anywhere you want it easily.
Dave Covey
Re: Inside car battery shut off [Re: Chief] #2892657
02/24/21 12:39 PM
02/24/21 12:39 PM
Minnesota, USA
humpty Offline OP
humpty  Offline OP
Minnesota, USA
[/quote]
Dave [/quote]
I looked at those but couldn't figure out how to actuate them from two points. Either way - I can see tech having an issue with them. It would be a nice setup with a big red kill button within easy reach.
