Page 3 of 3 1 2 3
Re: Which is Faster, Bore & Stroke ? [Re: B1MAXX] #2892239
02/23/21 01:11 PM
02/23/21 01:11 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I was not referring to factory stock block....Just looking at somthing to see which way a person would build an engine to a cube inch limit for max power NA....The over riding response seems to be the biggest bore you can get.
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2892300
02/23/21 02:57 PM
02/23/21 02:57 PM
gregsdart Offline
gregsdart  Offline
Since stock block overbore is limited to 4.400 or less, i assume most of us figured on aftermarket blocks. The best combo might be a 4.560 bore 4.25 stroke for 555 cubes. But not many want to take a good block to the limit if they don't have to.
I became a believer in big bores when my first megablock combo went 8.70s at 3055 lbs with 440-1 heads, and 13.4 compression. 528 cubes, 4.15 stroke 4.50 bore. Cam was only 280/290 @ .050 and .760 lift
Re: Which is Faster, Bore & Stroke ? [Re: gregsdart] #2892329
02/23/21 03:46 PM
02/23/21 03:46 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Well hell let’s take all those stroker cranks, small block and big block, and throw them in the trash since the BORE makes so much power. I guess the big 3, Cat, Cummins, Offy-Drake, ships, freight trains, any and all got it all wrong.
Re: Which is Faster, Bore & Stroke ? [Re: Al_Alguire] #2892330
02/23/21 03:48 PM
02/23/21 03:48 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by Al_Alguire
Comp Eliminator is a performance based cubic inch "limited" class. I don't know of ANYONE who chooses stroke over bore to get to the desired cubic inch number. Even the two blown SB combos I am aware of.
Unlimited RPM. RPM = horsepower - if you can move the air
Re: Which is Faster, Bore & Stroke ? [Re: cudaman1969] #2892331
02/23/21 03:49 PM
02/23/21 03:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
None of those run 7k. Or even half that normally.
Re: Which is Faster, Bore & Stroke ? [Re: cudaman1969] #2892341
02/23/21 04:10 PM
02/23/21 04:10 PM
Washington
madscientist Offline
Washington
If you want to do a lot work over a long time, then stroke is your friend. If you want to do a lot of work over a shorter time, then bore and RPM win every single time.
Re: Which is Faster, Bore & Stroke ? [Re: madscientist] #2892351
02/23/21 04:33 PM
02/23/21 04:33 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Very interesting topic, I read some of the major race engine builders have always felt that full race it all about the big bore.
One of my bucket list projects for a streeter has been a under square street/light tnt 3.950 bore on a 4 inch crank since they say ... low rpm/high tq.
In this case im not sure if im going to see any drastic changes vs our common stroker builds, but who knows.
STOP POTATO HATE!
Re: Which is Faster, Bore & Stroke ? [Re: CMcAllister] #2892374
02/23/21 05:21 PM
02/23/21 05:21 PM
fredericksburg,va
fredericksburg,va
They don’t have too rev to make the power to push those heavy loads. One point the 383 and 400, both have same crank but 400 much bigger bore. What’s the difference in HORSE POWER from each? What maybe 5, Negligible
Re: Which is Faster, Bore & Stroke ? [Re: cudaman1969] #2892406
02/23/21 06:53 PM
02/23/21 06:53 PM
AndyF Offline
AndyF  Offline
At the low RPM the factory rated those engines it didn't really matter that much. Besides, the factory ratings were rarely correct. The numbers were usually fudged for marketing reasons. Any race engine builder will tell you that bore size makes power in a wedge headed engine. People have known that for at least the last 50 years if not longer. The big problem with making power that way is finding a big bore block. In the old days they didn't exist. These days they exist but they cost a lot so the average racer doesn't mess around with big bore combinations. A 4.500 bore is probably the largest bore size that the average bracket racer will ever get their hands on, especially a Mopar guy. Chevy guys and some Ford racers have the option of larger bores.
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2892416
02/23/21 07:18 PM
02/23/21 07:18 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
as long as the bore on the small bore engine is big enough to not restrict the airflow needed at 7000 RPM then they would be very similar and abiltity to package it is a bigger priority.
Re: Which is Faster, Bore & Stroke ? [Re: Dragula] #2892458
02/23/21 08:26 PM
02/23/21 08:26 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A very smart person you never heard of (Dr. F. W. Lanchester) provided an answer over 100 years ago.
Where:
HP = maximum power
B = bore diameter
S = stroke length
N = number of cylinders
C = a constant for fuel quality, materials, construction standards
HP = B^1.65 × S^.5 × N × C
Note that bore to stroke ratio, number and position of cams, valve train design, valve size and number, rod to stroke ratio do not appear.
Boffin Emeritus
Re: Which is Faster, Bore & Stroke ? [Re: polyspheric] #2893758
02/27/21 03:30 PM
02/27/21 03:30 PM
Souderton
Taylor Offline
Taylor  Offline
Souderton
Where:
HP = maximum power
B = bore diameter
S = stroke length
100 years ago no one understood their respective influence on the internal combustion engine.
limiting yourself to 7k rpms makes it a crap shoot between square, over square and under square Bore Vs Stroke.
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
Re: Which is Faster, Bore & Stroke ? [Re: Taylor] #2893867
02/27/21 07:49 PM
02/27/21 07:49 PM
New York
polyspheric Offline
polyspheric  Offline
New York
No, 100 years ago THAT person understood their respective influence on the internal combustion engine.
Boffin Emeritus
Re: Which is Faster, Bore & Stroke ? [Re: 67_Satellite] #2893893
02/27/21 09:25 PM
02/27/21 09:25 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Originally Posted by 67_Satellite
A lot of other factors go into which would be "quicker", but for a given engine family, go with the biggest bore which is practical, then adjust stroke to get the cubes desired.
Anybody think this statement is out in left field yet? Works for just about any situation.
Re: Which is Faster, Bore & Stroke ? [Re: polyspheric] #2893967
02/28/21 08:32 AM
02/28/21 08:32 AM
Souderton
Taylor Offline
Taylor  Offline
Souderton
That Person was an Aviation and Military Genius, but what we have learned in the last 100 years ADDS a ton more perspective to the OTHER factors that good ole Freddy considered insignificant.
Re: Which is Faster, Bore & Stroke ? [Re: Taylor] #2894031
02/28/21 12:15 PM
02/28/21 12:15 PM
New York
polyspheric Offline
polyspheric  Offline
New York
And none of it contradicts what he said.
Boffin Emeritus
Re: Which is Faster, Bore & Stroke ? [Re: polyspheric] #2894074
02/28/21 02:31 PM
02/28/21 02:31 PM
fredericksburg,va
fredericksburg,va
And I might add there were a ton of SMART people around about that time, telling us how the universe works and all. But the internal combustion engine was to much for them, to hard to understand!
Had to go get the spelling right
Einstein
Curie
Newton
Tesla
Planck
Salk
Bohr
Just name a few from a 100 years ago
Re: Which is Faster, Bore & Stroke ? [Re: cudaman1969] #2894123
02/28/21 04:54 PM
02/28/21 04:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Newton didn't try the ICE and fail.
It wouldn't exist for another 200 years.
Boffin Emeritus
Re: Which is Faster, Bore & Stroke ? [Re: polyspheric] #2894135
02/28/21 05:29 PM
02/28/21 05:29 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
A good example might be a 413 vs a 400. The extra 13 cubes wouldn't win me over.
Page 3 of 3 1 2 3
