rear main bearing seal #289162
04/15/09 03:01 PM
04/15/09 03:01 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
Do i eed to trim off that porton of the seal that protrudes above the cap 0,05 inch it is a felpro
Re: rear main bearing seal [Re: kennetto] #289163
04/16/09 11:24 AM
04/16/09 11:24 AM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
anyone
Re: rear main bearing seal [Re: kennetto] #289164
04/16/09 11:45 AM
04/16/09 11:45 AM
BB or SB
Re: rear main bearing seal [Re: RapidRobert] #289165
04/16/09 01:23 PM
04/16/09 01:23 PM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
big block
Re: rear main bearing seal [Re: kennetto] #289166
04/16/09 02:34 PM
04/16/09 02:34 PM
Rope seal cut it off flush
Re: rear main bearing seal [Re: RapidRobert] #289167
04/16/09 02:36 PM
04/16/09 02:36 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Are you talking about the two little "wedge" shaped gaskets that seal the side of the rear cap to the block?
Re: rear main bearing seal [Re: burdar] #289168
04/17/09 11:08 AM
04/17/09 11:08 AM
Sweden
K
kennetto Offline OP
kennetto  Offline OP
K
Sweden
No it is the rubber gasket upp and down
