Here is what happens when you mix 727 Parts
#2890908
02/20/21 10:33 AM
02/20/21 10:33 AM
Posts: 1,328 VA
dragon slayer
VA
So, I am taking apart another transmission, this one was complete. A 71-72 440 HP This one being a 72 model assembled 28Mar72. Not sure of it's history, but it was bound up. After removing VB, could not get park rod out and nothing would turn. Had to unclip rod from VB.
I removed the oil pump housing and immediately everything freed up and rotated at input and output. Will say this trans is immaculate inside, all the parts seem original to the trans and have casting numbers Feb72 and in some case 3rd week of Mar72 casting dates which I found interesting. Additionally it had a 8 thousand assembled number. Which I can't believe is in a day, unless that is what they did.
So after I started looking closer at the pump and front drum, I found that it had a mismatch. The narrow bushing RSS, and a wide bushing front drum. Hence the no thrust and locked up drive train. So I examined what the drum looks like placed on that reaction shaft. You can see the gap well greater then what the fiber washer thickness would be. So I scratched my head how the oil pump even fully seated? Well some of the oil housing bolts show signs of stress on the threads. Then as I looked closer at the bushing of the front drum, it was being pressed out of the drum by the tightening of the oil pump housing. About a 1/16+".
So at some point the oil pump was swapped and caused this issue. Bands, clutches, springs all pristine, even ink stamp inspection numbers and such are still present, including the oil pump housing. The narrow band RSS has a ring ridge that sits higher up then a wide bushing support. It contacts the bushing and prevents a narrow reaction shaft from fully inserting into the front drum. Because it is much different the pump housing can not fully seat. If you do seat the pump housing, that ridge presses the bushing out while binding the drive train eliminating any thrust clearance. Pictures below.
Re: Here is what happens when you mix 727 Parts
[Re: dragon slayer]
#2891317
02/21/21 08:25 AM
02/21/21 08:25 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Must have happened in the 80's before computers were invented... Even us limeys know about post 71 wide drums... Twice as many post 71 727 trans as pre 71's? 66-70 and 71-78 ish... Who would use a pre 71 transmission anyways???
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
