Re: Come on ... BE HONEST...what do you properly TORQUE... ?
[Re: dOOc]
#2890806
02/19/21 11:19 PM
02/19/21 11:19 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Pretty much just cam sprockets, bearing caps and head bolts. But with over 45 years as an auto mechanic I have a pretty good feel for things.
[Re: Stanton]
#2890915
02/20/21 10:51 AM
02/20/21 10:51 AM
Posts: 10,741 North Dakota
6PakBee
North Dakota
I torque everything that has a specification. I find that even after decades I tend to over tighten smaller fasteners (< 3/8" or so) and under tighten larger fasteners (> 3/8" or so). I've gone to grade 8 on any 1/4" bolt as I pop the stock fasteners like candy. Intake gasket end rails on a BB as one example. The only notable exception is the oil pan. That I use gasket compression to know when to stop.
[Re: 5thAve]
#2890987
02/20/21 12:57 PM
02/20/21 12:57 PM
Posts: 4,446 Michigan
MarkZ
Worthy
Worthy
Head bolts, rod bolts, main caps, rockers shaft bolts, etc. Don't think I've ever torqued intake bolts, oil pan bolts or anything on the front of the motor for that matter. I'm anal about the tightening sequence though.
[Re: moparjim79]
#2891056
02/20/21 02:37 PM
02/20/21 02:37 PM
Guitar Jones
Incremental is the way it should be done and the way I like to do it, but let 's face it, unless this is a high performance car it probably isn't going to matter. There is a difference between a race engine and a stock daily driver. For instance, for a driver just torquing rod bolts is fine, for a race engine, the bolt stretch method should be mandatory.
[Re: dOOc]
#2891099
02/20/21 03:47 PM
02/20/21 03:47 PM
Posts: 25,901 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since the OP wasn't engine-specific, don't forget lug nuts.
[Re: 6PakBee]
#2891132
02/20/21 04:35 PM
02/20/21 04:35 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
I torque everything that has a specification. I find that even after decades I tend to over tighten smaller fasteners (< 3/8" or so) and under tighten larger fasteners (> 3/8" or so). I've gone to grade 8 on any 1/4" bolt as I pop the stock fasteners like candy. Intake gasket end rails on a BB as one example. The only notable exception is the oil pan. That I use gasket compression to know when to stop. About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2891198
02/20/21 08:30 PM
02/20/21 08:30 PM
Posts: 3,089 Michigan
A727Tflite
I torque everything that has a specification. I find that even after decades I tend to over tighten smaller fasteners (< 3/8" or so) and under tighten larger fasteners (> 3/8" or so). I've gone to grade 8 on any 1/4" bolt as I pop the stock fasteners like candy. Intake gasket end rails on a BB as one example. The only notable exception is the oil pan. That I use gasket compression to know when to stop. About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws. Just like the vehicle assembly plants - they use DC nut runners on everything. And the manufacturing plants use them too along with “multiples”.
[Re: Hemi_Joel]
#2891223
02/20/21 09:27 PM
02/20/21 09:27 PM
Posts: 1,408 Central Pa
moparjim79
Central Pa
[/quote] About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws. [/quote] That was awesome
