Re: Questions about RMVBs
[Re: jlatessa]
#2890548
02/19/21 03:10 PM
02/19/21 03:10 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
LBA (1st gear braking) helps prevent sprag failure which can lead to explosion.
Clean Neutral is an added shifter position that allows shifting to Neutral without having to pass through 3-2-1. This is mostly for drag racers who don't want to decelerate in gear after a run...takes strain off the rods and makes spark plug reading possible.
[Re: jlatessa]
#2890562
02/19/21 03:33 PM
02/19/21 03:33 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
Drove a Rmvb with no low gear braking on the street for about 10yrs. Never had a problem. The person who made the VB told me in no uncertain terms to never downshift into low. That the only time the vb is placed in low is when at a complete stop. So thats what I did. Loved that vb, was better thana turbo action and the griner that followed.
Ok
[Re: jlatessa]
#2890609
02/19/21 04:37 PM
02/19/21 04:37 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Thanks guys, then what is the benefit of no 1st gear braking?
Joe It is supposed to allow the shift to be quicker because the band doesn't have to release. I have coasted mine in low gear many times with no ill effects or sprag problems. Never at high speed but Its not uncommon for me to knock it down into low as I roll up to an intersection. With my 727 it did that for 14-15 years at least for thousands of miles of driving, my 904 not as much but plenty. If I ever move to a low bad apply VB I will probably eat the steering wheel a few times before I change my ways haha.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2891089
02/20/21 03:28 PM
02/20/21 03:28 PM
John_Kunkel
Rio Linda, CA
Its not uncommon for me to knock it down into low as I roll up to an intersection. There seems to be a misconception about this, many think it's harmful to the sprag but, in reality, it isn't.
