Re: wheel spacers?
[Re: lewtot184]
#289026
04/15/09 12:25 PM
04/15/09 12:25 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Make sure to keep your lug nuts tight. Check regularily. These spacers have been used for years contrary to what all the naysayers say. If they were as dangerous as these naysayers say they would have been pulled off the market years ago.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
Re: wheel spacers?
[Re: lewtot184]
#289027
04/15/09 12:32 PM
04/15/09 12:32 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
5x5.5 will require a bolt-on adapter. I was going to use the Mr gasket cast aluminum ones on my car, until they cracked at 60 ft-lbs. spend the $$ on billet. I got mine from http://crowautomotive.com/ for $192/set 6 years ago and have held up great.
Re: wheel spacers?
[Re: lewtot184]
#289029
04/15/09 01:04 PM
04/15/09 01:04 PM
patrick
Grand Haven, MI
sorry, I thought the 5 1/2 was BP, not width...
cast "through" spacers are OK, but you may need longer studs...
Re: wheel spacers?
[Re: Jerry]
#289032
04/15/09 03:40 PM
04/15/09 03:40 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
i can whip you up a set of billet aluminum spacers that you won't have to worry about them failing for a little more than the cast ones. but when safety is concerned i would err on the side of caution. also my spacers are hub centric so everything lines up like it should
Hub centric really should be the only way to go ...
Re: wheel spacers?
[Re: 64Post]
#289033
04/15/09 04:08 PM
04/15/09 04:08 PM
Posts: 15,487 Florida
scratchnfotraction
just dont stack washers on the studs to hold the rim out and only catch a couple threds on each stud if you do...dont drive down town to the walk in theater and do a one wheel burn out around the corner and have a 10" wide keystone rim come off and roll into the back panel of your duster and knock a big dent into it.... in front of of the whole crowd....DAMHIK..I was 15 yrs and my first mopar jacked up with the mag wheels,4 on the floor and a peace sign but yea you can run them if its done right and check them often,IMO good luck
