Re: CNC max wedge intake
[Re: jwb123]
#2889186
02/16/21 01:24 PM
02/16/21 01:24 PM
Posts: 9,835 MI, usa
dvw
MI, usa
When I was building my car I was willing to spend $2000 to port a max wedge intake. If it could be on par with an Indy 440-25. Couldn't find anybody. When the 440-25 was first released I backed to backed a factory crossram vs an Indy 440-25. Same day on the dyno, same carbs. 498 with box stock -1 heads, .650 roller, 12-1, 2 Eddy 750's. 658@5700 vs 712@6700. From 4000 up the Indy was better. Doug
[Re: dvw]
#2889280
02/16/21 04:20 PM
02/16/21 04:20 PM
Posts: 1,442 central ohio
nss guy
central ohio
When I was building my car I was willing to spend $2000 to port a max wedge intake. If it could be on par with an Indy 440-25. Couldn't find anybody. When the 440-25 was first released I backed to backed a factory crossram vs an Indy 440-25. Same day on the dyno, same carbs. 498 with box stock -1 heads, .650 roller, 12-1, 2 Eddy 750's. 658@5700 vs 712@6700. From 4000 up the Indy was better. Doug Did the crossram peak at 5700??
[Re: nss guy]
#2889437
02/16/21 09:42 PM
02/16/21 09:42 PM
dvw
MI, usa
When I was building my car I was willing to spend $2000 to port a max wedge intake. If it could be on par with an Indy 440-25. Couldn't find anybody. When the 440-25 was first released I backed to backed a factory crossram vs an Indy 440-25. Same day on the dyno, same carbs. 498 with box stock -1 heads, .650 roller, 12-1, 2 Eddy 750's. 658@5700 vs 712@6700. From 4000 up the Indy was better. Doug Did the crossram peak at 5700?? Yes
[Re: XXHEMI]
#2889473
02/16/21 11:43 PM
02/16/21 11:43 PM
Posts: 201 PA
Scully
PA
Jon Kasse took one of my stock 63 intakes as a science project about 7 years ago. On the dyno with untouched intake the motor made 698 HP with 286 heads done by Kasse as well. Same day 45 minutes later with the ported manifold 780HP. Picked up 5 tenths right away! Largest gain we ever made with the motor!
Since that day the motor has gone through many many changes, and what ever we do still make 780? I can only think that the Intake is just maxed out? Maybe the heads? But I think its the Intake.
What carbs were on it, do you know what the heads flowed.
[Re: Scully]
#2889541
02/17/21 10:11 AM
02/17/21 10:11 AM
Posts: 731 NY
XXHEMI
NY
What carbs were on it, do you know what the heads flowed. I had a flow sheet on the heads that I can't seem to find? From what I recall one set flowed 324? Maybe Dwayne Porters remembers he did a lot of work to them with Mike from HP motors. (If he pop's in?) Carbs where 750's that Dale at CFM opened up to I think 950's The motor was built for FAST racing so we where stuck using a lot of stock components Doug I will try to get some pictures of inside the manifold?
[Re: B G Racing]
#2889673
02/17/21 03:42 PM
02/17/21 03:42 PM
Posts: 3,504 DFW
mr_340
DFW
Marlin Bogner had these heads and intake for sale about 20 years ago. I want to say he said that Batten did the heads and intake work.
Floyd Lippencott IV
[Re: XXHEMI]
#2889882
02/18/21 12:23 AM
02/18/21 12:23 AM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
What carbs were on it, do you know what the heads flowed. I had a flow sheet on the heads that I can't seem to find? From what I recall one set flowed 324? Maybe Dwayne Porters remembers he did a lot of work to them with Mike from HP motors. (If he pop's in?) Carbs where 750's that Dale at CFM opened up to I think 950's The motor was built for FAST racing so we where stuck using a lot of stock components Doug I will try to get some pictures of inside the manifold? I think the carbs were 800's that were opened up. Do you know or know of anyone currently running them that could provide setting them up?
