I'm back!
#2889058
02/16/21 09:31 AM
02/16/21 09:31 AM
Posts: 2,309 Tomorrow.
Damned67
Tomorrow.
Hi All! I've been a member of the current board since 2003 or something like that. A tonne of posts over the years, but pretty much stopped about 10 years ago, or there abouts. I pop in every year or so to see how everyone is doing and whats happening, but it kinda got depressing. My interest in the car got diverted by fishing and then surfing.... but in recent months my 16 year old daughter has started expressing interest in the car, and the wife-boss has been saying that if I'm not doing anything with it, then I need to get rid of it..... and that ain't happening! So, I have a re-invigorated interest in the car.
Car is a '67 Belvedere with a 505" spec'd out by Dan from Performance Only, about 15 years ago: Engine is a E-headed (stage 1? port by Dan), 10.4:1 505", 0.587/0.593 287/294 cam, M1 intake and 1050 Dominator (8896). Dominator has been converted from 3 to 2- circuit with QuickFuel metering plates. It was an impressive engine 15 years ago...seems much less so now. Callies Crank, Oliver Rods, Diamond Pistons.
Plan for this weekend is to spend some quality time with the daughter trying to tune it, again. My guess is that we'll really need to be looking at a carb rebuild kit.... but we can spend some time with it first. Got to find excuses these days.
Long story short, expect some really SIMPLE questions from me over the coming weeks/months. It's been so long since I've given it any real attention that I've pretty much forgotten everything that I used to know (or think I knew). I look forward to chatting some more about getting this back on the street (or strip) where it belongs!
Cheers!
Re: I'm back!
[Re: Damned67]
#2889401
02/16/21 08:44 PM
02/16/21 08:44 PM
Posts: 43,172 Bend,OR USA
Cab_Burge
Make sure and use new fresh fuel, if there is any old fuel in the tank at all drain it and throw it away I would pull both fuel bowls and see if there is any gunk or corrosion inside them and clean as needed, if none is in it their run it How much experience does she have driving now? Are you wanting her to race it? Neither one of my kids wanted to drive my drag cars when they were younger and living at home, my middle grandson would drive any of my cars now in a hot second including my S/P car Maybe someday
Re: I'm back!
[Re: slantzilla]
#2889439
02/16/21 09:47 PM
02/16/21 09:47 PM
Posts: 1,030 ohio
67mprfan
ohio
This thread needs pictures..... Welcome back
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: I'm back!
[Re: Damned67]
#2889594
02/17/21 12:05 PM
02/17/21 12:05 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
I've had a beer or two with that car. : ) I remember the picture of your wife running the engine hoist in the evening gown too..that was a lot of years ago (20ish?)
Glad you are getting it back out!
Re: I'm back!
[Re: Jeremiah]
#2889879
02/18/21 12:18 AM
02/18/21 12:18 AM
Damned67
Tomorrow.
Glad you are getting it back out! Hey Jeremiah! Yeah, that was a good few years ago. I reckon 16-17 years. Does not seem that long ago.
Re: I'm back!
[Re: Damned67]
#2889933
02/18/21 09:21 AM
02/18/21 09:21 AM
Damned67
Tomorrow.
Came upon our first hurdle for our proposed 'tuning' day - damn balancer no longer has any timing marks on it! Just rust.
It's a Powerbond that Dan from Performance Only suggested I use, lack of use and care clearly led to it being nothing much more than rust. For some bizarre reason that I can't recollect, the engine was assembled with a Precision Performance balancer, that I still have. I just can't remember why I changed it over? I just can't remember if there was an issue with the Precision Performance balancer, or if I simply forgot to give the Powerbond to the crew that assembled the engine for me, and they supplied (at my cost) the precision balancer,
I really don't think I've turned a screw to tune the engine in about 10 years, and it probably hasn't even been on the street in over 5 years.
I turn it over occasionally, and if it sits for too long, I pull the distributor and prime with a priming rod, so really need to double check the timing (although it did fire up last weekend OK). I mark the distributor and rotor, so it should be reasonably close. I just remember that when I did install the Powerbond balancer, I managed to mess up the key. So, somewhat hesitant to do it again.
Anyway, this weekend might be more of a degrease the engine and clean it all up, as opposed to doing some tuning. Passenger side valve cover gasket is leaking like a sieve anyway, so we can at least replace those this weekend.
Re: I'm back!
[Re: Damned67]
#2890020
02/18/21 12:20 PM
02/18/21 12:20 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Welcome back! This place has slowed down quite a bit. At least, anything posted will hang there for a long time before it gets buried.
Rich H.
Esse Quam Videri
