Page 39 of 48 1 2 37 38 39 40 41 47 48
Re: Modern Bullitt build [Re: Keepat] #2882584
01/31/21 09:03 PM
01/31/21 09:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Originally Posted by Keepat
Windshield trim install with no problems other than sore palms;-)
Pat
I found that if you use a plastic trim stick and get behind each clip and flex the clips pretty good it will allow the trim to go in a whole lot easier.
Re: Modern Bullitt build [Re: Keepat] #2883035
02/02/21 10:24 AM
02/02/21 10:24 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Originally Posted by SRT6776
Are you keeping it or selling it when its done?
Keeper!
Congrats if you are, any level build/documented like this tends to be on the auction block 2 weeks after completion. Can't wait to see it when its done, gorgeous car.
Re: Modern Bullitt build [Re: SRT6776] #2886514
02/10/21 07:32 PM
02/10/21 07:32 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Slowly cutting, sanding and fitting the exhaust puzzle piece by piece;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2888686
02/15/21 01:08 PM
02/15/21 01:08 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Slowly working my way aft piece by piece. I’m trying to keep the exhaust as close to the floor as to not see any of it hanging down from a side profile. Using welded on exhaust flanges certainly clean up the appearance.
Pat
Re: Modern Bullitt build [Re: Keepat] #2888821
02/15/21 04:56 PM
02/15/21 04:56 PM
mopar4don Offline
mopar4don  Offline
Wow, now that is some art work!
Beautiful Pat
Re: Modern Bullitt build [Re: mopar4don] #2888894
02/15/21 07:29 PM
02/15/21 07:29 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Beautiful Pat
Thanks Don! I think this is the closest I’ll ever get to metal sculpture;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2889901
02/18/21 01:23 AM
02/18/21 01:23 AM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
A question/comment. Is there a reason you went with an X-pipe over an H-pipe crossover? My own ear likes the more "classical" sound of the H-pipe. Can't wait to see you take it for the first drive, though.
Re: Modern Bullitt build [Re: Keepat] #2889997
02/18/21 11:26 AM
02/18/21 11:26 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
this will be to nice to ever see the streets ! very nice. outstanding work..... up
Re: Modern Bullitt build [Re: Greenwood] #2890354
02/19/21 08:01 AM
02/19/21 08:01 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Going with the X pipe will make for a much cleaner installation of the exhaust cut outs as I can install them right at the first curve aft of the headers. After over six years I am so looking forward to driving this car down the road!
Pat
Re: Modern Bullitt build [Re: ek3] #2890355
02/19/21 08:03 AM
02/19/21 08:03 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Won’t make it this year but be sure this car will go on the hotrod power tour in 2022.
Pat
Re: Modern Bullitt build [Re: Keepat] #2891447
02/21/21 12:46 PM
02/21/21 12:46 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With the exhaust tack welded in place forward of the mufflers, I have started working on the tail pipes. Unfortunately with the inboard mounted 4 link I have to modify the TTI tail pipes to fit.
Pat
Re: Modern Bullitt build [Re: Keepat] #2892859
02/24/21 09:36 PM
02/24/21 09:36 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I finished up the tail pipes, just need to cut the slash tips off to install the rectangular polish stainless exhaust tips. Then I started working on the cut outs. Fortunately one of our belt sanders is the same dimensions as the exhaust!
Pat
Re: Modern Bullitt build [Re: Keepat] #2892906
02/25/21 12:58 AM
02/25/21 12:58 AM
Tucson AZ,
MadMopars Online content
MadMopars  Online Content
Tucson AZ,
Beautiful work, as always! up
That being said, when are you going to get that roller rear end out of there and get the Dana installed? whistling wink
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Modern Bullitt build [Re: MadMopars] #2892981
02/25/21 11:05 AM
02/25/21 11:05 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Maybe we should put a Dana in my son’s 68 Mustang to balance things out;-)
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2894170
02/28/21 07:30 PM
02/28/21 07:30 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Cutouts and S/S tips are fitted! Time to tig weld all the seams and have the exhaust ceramic coated to match the headers.
Pat
Re: Modern Bullitt build [Re: Keepat] #2894278
03/01/21 07:21 AM
03/01/21 07:21 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat your craftsmanship and attention to detail is amazing!
I hope to see this car one day.
-larry
Re: Modern Bullitt build [Re: larry4406] #2894594
03/01/21 10:10 PM
03/01/21 10:10 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
-larry
Thanks Larry! It will be at Carlisle this summer!
Pat
Re: Modern Bullitt build [Re: Keepat] #2894657
03/02/21 06:50 AM
03/02/21 06:50 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
-larry
Pat
Thanks Pat - I hope to make it this year!
Re: Modern Bullitt build [Re: larry4406] #2895883
03/04/21 11:12 PM
03/04/21 11:12 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
All welded up and I will be delivering it to JetHot Saturday for a polished ceramic coating. All of the amateur welds that you can’t see are mine and all of the visible welds are by a good friend and expert welder. A man’s got to know his limitations;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2897893
03/10/21 08:24 PM
03/10/21 08:24 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
That's beautiful work. up
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
