help selecting the right carb
#288849
04/15/09 02:16 AM
04/15/09 02:16 AM
Posts: 63 minnesota, USA
greenfire
minnesota, USA
hi, newb here i have a 74 satellite sebring plus with a 318 that appears to have a stock 4 bbl manifold and a stock 4bbl carb. the carb is junk and i want to replace it. i think there is an egr valve also. what would be a good replacement carb? a edelbrock 600 cmf ? and can i use the stock manifold? or do i need to go with a after market one? also can i get rid of the egr valve? any help is greatly welcomed.
proud new owner of a 1974 plymouth satellite sebring plus in decent shape, let the fun begin
Re: help selecting the right carb
[Re: greenfire]
#288850
04/15/09 02:21 AM
04/15/09 02:21 AM
whats the list numbers for the carb thats on it now?
#288851
04/15/09 02:30 AM
04/15/09 02:30 AM
greenfire
minnesota, USA
this is whats stamped on the top of the carb, carter thermo quad 16 and then the #6-2141
[Re: greenfire]
#288852
04/15/09 02:37 AM
04/15/09 02:37 AM
to the best of my knowledge the lowest thermoquad cfm rating was 750. actually with most motors it seems that you would need a smaller holley or edelbrock carb for some reason. the 600 edelbrock seems like it should be fine. except i found out that 600 on my 318 was too much carb for it until it got to the high rpms. on holleys website they have a carb calculator that said my engine needs a 390-570 cfm carb. do you have any mods on the engine?
#288853
04/15/09 02:41 AM
04/15/09 02:41 AM
greenfire
minnesota, USA
other then duel exhaust, none that i no of, i just got the car a few weeks ago
[Re: deansrr]
#288855
04/15/09 12:49 PM
04/15/09 12:49 PM
greenfire
minnesota, USA
other then having the body work done, for now just want to up grade the carb. who knows what will follow down the road lol
