Re: Fan Belt Keeps Coming Off
[Re: Pacnorthcuda]
#2888096
02/14/21 01:05 PM
02/14/21 01:05 PM
Posts: 259 n.c.
geo.
n.c.
I had(have) the same problem with my then 318 powered Challenger. I used to autocross a few times a year with the car, it was common to lose the fan belt during a run. Someone suggested removing the fan and fan clutch before a run. It worked, belt stayed on! If you're still running a stock style clutch and metal fan I'd try a run with fan removed. I'd drive to the event and remove the fan, wasn't too hard to do, and replace for the ride home. I don't know if there's a lighter fan and clutch I can try. Or if the fix is going to be adding an electric fan.
[Re: patosmith]
#2888107
02/14/21 01:17 PM
02/14/21 01:17 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
How are you checking your pulley alignment? Are you using a straight edge, a lazer pointer or a wooden dowel? It's not as easy to do correctly as most people think, and close enough often isn't. What thickness belt are you using? Does it fill the entire v-groove of the pulley? Does it stick up beyond the groove?
Look closely at each pulley where the belt begins to contact the pulley. There are two places to check on each pulley. Does the belt touch one side of the pulley wall more than the other at these 6 locations?
More pictures of these locations would be helpful.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: patosmith]
#2888166
02/14/21 02:15 PM
02/14/21 02:15 PM
Posts: 1,707 central il.
second 70
central il.
I have a 72 Challenger with a big block. When I make a pass, the fan belt comes off. The belt is a "V" belt and drives the water pump and alternator. I have checked pulley alignment and I can't find anything off. I have tried different width belts. Right now I have a pretty skinny belt on and seems to stay on but it is not right. I really do not want to go with a serpentine setup. Any ideas?
Easy fix put a dayco top cog belt on it and that will fix it. I couldn't keep a belt on my hemi and then switched to a dayco and haren't tossed a belt in over 10 years. I use a 15470 belt. Mike
[Re: patosmith]
#2888200
02/14/21 02:50 PM
02/14/21 02:50 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
They cured that problem on the Max Wedge by going to deeper groove pulleys. IOW, a 3/8" belt in pulleys designed for a 7/16" belt. (truck?)
[Re: moparjim79]
#2888280
02/14/21 05:18 PM
02/14/21 05:18 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
You might try loosening up the tension a bit. Sounds crazy, but it works.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: second 70]
#2888295
02/14/21 05:47 PM
02/14/21 05:47 PM
Posts: 10,135 A Red State
SNK-EYZ
A Red State
Easy fix put a dayco top cog belt on it and that will fix it. I couldn't keep a belt on my hemi and then switched to a dayco and haren't tossed a belt in over 10 years. I use a 15470 belt. Mike I had the same problem with our 69 Dart 383 GTS that has a 451 stroker in it. It threw every standard type V-Belt. I switched to a DAYCO top cog V-Belt and haven't thrown one yet. The Dayco Top Cog Belt sits lower (farther) into the pulley grooves when installed.
[Re: FurryStump]
#2889226
02/16/21 02:27 PM
02/16/21 02:27 PM
Posts: 9,117 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
I had this problem with a fast revving small block. Checked/adjusted pulley alignment multiple times, tried a boat load of different belts. Even tried a larger alternator pulley, nothing really worked. I finally put a reduction pulley (smaller diameter) on the crank and went back to the stock alternator pulley and the problem was solved.
[Re: patosmith]
#2893942
02/28/21 01:18 AM
02/28/21 01:18 AM
Posts: 68 southeast NE
lemondana
southeast NE
Post the brand and number of belt you now have on the car.
[Re: patosmith]
#2894375
03/01/21 01:18 PM
03/01/21 01:18 PM
Posts: 5,162 CT
GTX MATT
CT
The alternator is in the stock location but I think you hit on what my thought was. The length of the belt between the crank pulley and the alternator. That is the only thing I can come up with. I have tried to find a deep pulley for the alternator to see if that helps but haven't had any luck finding one. I am looking into a tensioner on Mancini Racing but I'm not sure if it will fix the problem. The pic I posted is not a good shot but you can see the location of the alternator.
Stock location but it looks a little high, do you have a picture of your alternator bracket? It could be the angle, but make sure you don’t have an AC lower bracket, this makes the belt needed much longer. What do you have for a fan?
[Re: dvw]
#2894741
03/02/21 11:18 AM
03/02/21 11:18 AM
Posts: 15,372 Omaha Ne
TJP
Omaha Ne
Put a straight edge on the alternator pulley. My bet is that its centerline is off in at least one plane. Or the pulley centerlines are forward or back from one another. The straightedge should stay perfectly square to both the crank and and water pump when placed on the alternator pulley. If the straightedge doesnt touch both faces of all three pulleys you have an issue. Do the same with the crank and water pump. I've had combos throw belts. Every time it's been one of 2 issues. Alignment or bracket flex. Currently have 3 cars. All have modified brackets, pulleys, etc. None of them ever through a belt. All run to at least 7000. Doug and will add the longer the distance is between the pulleys and the less contact around the pulley the more prone they will be to throwing the belt. Some of the c-2, c-3 corvettes used an adjustable belt guard that would not allow the belt to raise up enough to come out of it's groove. This was placed on the adjusting arm between the water pump near the alternator. NOTE: the alternator is the smallest pulley with the least amount of contact. This was on cars that had L (drivers side) mounted alternators. Another trick from years ago was to place a long 5/16 or 3/8 bolt just above the belt to limit its upward movement thereby kepping the belt in the pulleys. Again this was done between the alternator and water pump. Interesting that several have commented to Dayco top cog belts have resole their problem. I do know there are some slight variations on the belt V angles being made by different manufacturers. That may be the root cause
