Page 7 of 7 1 2 3 4 5 6 7
Re: Why aren't there more forced induction cars? [Re: BobR] #2887530
02/13/21 08:49 AM
02/13/21 08:49 AM
pa
572charger Offline
572charger  Offline
pa
/5000 hp what kind of car is it in ?? our door slammer [ promod] has a screw blown hemi thats around 3500 hp we take 1000 hp out to get it to move off the starting line 5.66 at 259 mph 1/4 3.67 at 208 in the 1/8
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Why aren't there more forced induction cars? [Re: 572charger] #2887532
02/13/21 09:10 AM
02/13/21 09:10 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That car sounds familiar. Lol.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Why aren't there more forced induction cars? [Re: 67_Satellite] #2887534
02/13/21 09:15 AM
02/13/21 09:15 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Originally Posted by 67_Satellite
Still loving mine after 10 years. Started with blow through, premium pump gas, and a 180K mile,8:0-1 compression, 383 with up to 15 lbs. Learned a lot with the "expendable" engine.#1 takeaway is to bullet proof your boost control devices. A melted W.G.. reference line, or a stuck wastegate will likely cost you at least a head gasket (or 2).Cheap blue Fel-pro gaskets make a great "Fuse".#2, don't get greedy with the timing. Stock junk will live -IF- you don't rattle it. I'm running 20 degrees total timing. I currently have the Sniper X-flow running pump E-85 on a 10:0-1 470 with two of the "Hong Kong Hurricane" 69 m,m, ebay turbos. Got a home made girdle, B.B.C. Eagle rods ,K.B. Icon pistons ,and haven't hurt the bottom end yet. Had it up to 17 lbs. with E-85 and the blow through carb. Got to the point where it couldn't get enough fuel through the "gas" downleg boosters ,so I decided to go to E.F.I. At just 12 lbs. it's uncontrollable below 60 m.p.h. Has 315-60 M/T drag radials, Cal track bars, Cal track shocks, 90/10 front shocks, and the traction gods don't care, but it is a blast to drive .I should add some safety equipment so i can take it to the track. I believe the old 383 would live forever with a 5500 r.p.m. shift point and 15 lbs. Don't be afraid to lean on the stock parts.
Pretty much the same for me with a 318 and I stayed with a carb. It's mind blowing what stock parts will absorb as long as you don't let it detonate. I've found that the upper limit of boost with 87 octane and a Snow alcohol injection system is just a bit shy of 18 psi of boost.
I got tired of the no torque bottom end of the 318 so it's out with the old and in with the new. I'm going to start fabbing up the hot side for the 446 on Sunday. I'm going to try and hold it under 600 hp, it's going in my used up 81' W-150.
Re: Why aren't there more forced induction cars? [Re: quickd100] #2887646
02/13/21 02:38 PM
02/13/21 02:38 PM
600 HP with a 440 N/A isn't real hard to do, with a hair dryer it should be fairly simple, 3 to 5 lbs. intercooled and go smoke em devil
Re: Why aren't there more forced induction cars? [Re: feets] #2887673
02/13/21 03:44 PM
02/13/21 03:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The big advantage to boost... since power can be produced at far lower RPM* than NA, you don't need $4,000 rocker arms, fabricated intake manifolds, stepped-tuned headers,1,000 lb. use-it-50-times-and-throw-it-away valve springs, $$$ connecting rods, and billet cranks.
How to tell which common engines work well with boost (produce X power from Y inches @ Z boost)? Everything produces more power with boost, but is there a reliable predictor for "if it does this at ATM it will do that @ 40 psi"? No. Port flow CFM and valve area per cubic inch, rod ratio are all factors but none are linear.
What to do? Use what everyone else uses (LS, BBC, Gen-2 hemi), or you're stepping way out on thin ice. Some untested engines may surprise you (how about the 289 Studebaker?), but others will produce hundreds of HP less than those mentioned at the same boost level.
* 8,000 RPM is not 33% more inertial load than 6,000 (8K ÷ 6K = 1.333), but 78% (8K^2 ÷ 6K^2 = 1.778).
Boffin Emeritus
Re: Why aren't there more forced induction cars? [Re: polyspheric] #2887787
02/13/21 08:16 PM
02/13/21 08:16 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Yep! It's nice to be able to drive something now and then that idles smoothly with normal street manners. Turbo motors are like Jekel and Hyde, once the turbo spools up it goes from Harvey Milk toast to hang on for dear life!
Re: Why aren't there more forced induction cars? [Re: polyspheric] #2887943
02/14/21 02:18 AM
02/14/21 02:18 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I beat the crap out of my TT440 trying to learn how to tune it. I broke some rings and ate a couple head gaskets along the way but never hurt the stock block, crank, or rods. It saw 6,000 RPM regularly but that was about it. It survived a boost spike to 22 psi when I lost a wastegate line.
- Stu Harmon
Re: Why aren't there more forced induction cars? [Re: feets] #2888362
02/14/21 07:41 PM
02/14/21 07:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Jim,.
Spotted a vid of of your Charger om the web.....
https://www.youtube.com/watch?v=ba1SC0lyRuU
Re: Why aren't there more forced induction cars? [Re: Dragula] #2889039
02/16/21 08:13 AM
02/16/21 08:13 AM
pa
572charger Offline
572charger  Offline
pa
yeah thats at a mopar show my friends put on every year we get 200 mopars there somtimes !!!!
Re: Why aren't there more forced induction cars? [Re: racerx] #2894601
03/01/21 10:24 PM
03/01/21 10:24 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Originally Posted by racerx
Originally Posted by Kam*Kuda
Here is the complete setup
500 inch
Fast XFI
F1X Procharger COG
Kind of off topic a little but a couple of ?......what mph are you pushing ? Is that 500"in a stock block? And how is that hood holding up?
Sorry I missed your question
Well the hood didn't do very well. The hood pins were crushed and the hood got a crack in the center I cut some holes in the back. I will get another hood soon.
I think it was 145 in the quarter
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
