Early Hemi into an B-Body #2885948
02/09/21 05:34 PM
02/09/21 05:34 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Anyone done it? 392 Hemi, what K-Frame and or Engine mounts?
Thanks for the help!!!
Admiration For Multiple Carburetor Vehicles...
Re: Early Hemi into an E-Body [Re: Stewpar] #2885998
02/09/21 07:29 PM
02/09/21 07:29 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Oh God, no....... Years ago I saw a 1969 Plymouth Belvedere station wagon that someone had shoehorned a 392 into with the matching cast iron TF. As I recall, the biggest challenge was keeping the front bumper from dragging. I can't remember if it was a PB, PS car but I can remember thinking that just because you can do something doesn't necessarily mean it's a good idea.
Re: Early Hemi into an E-Body [Re: Stewpar] #2886113
02/10/21 12:22 AM
02/10/21 12:22 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
I’ve seen a few out there. But, I’d go with a modern 392 over the old one.
China is the enemy.
Re: Early Hemi into an E-Body [Re: 1972CudaV21] #2886592
02/10/21 11:09 PM
02/10/21 11:09 PM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
A 392 in a rod or kustom... or a 3G in your B, which is a relatively easy swap now..... but this would be different.
Re: Early Hemi into an E-Body [Re: Jer] #2886859
02/11/21 06:32 PM
02/11/21 06:32 PM
Indiana
68_661charger Offline
Indiana
I have some pictures around here of a 70 Charger in an Indiana junkyard with an early hemi in it from maybe 12 years ago. It struck me as interesting but odd at the time.
Re: Early Hemi into an E-Body [Re: 68_661charger] #2886870
02/11/21 07:02 PM
02/11/21 07:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Early is wider than the gen II
Re: Early Hemi into an E-Body [Re: 6PakBee] #2886923
02/11/21 09:11 PM
02/11/21 09:11 PM
I think the 426 gen 2 hemi is heavier than the 331,354 and 392 scope
I have no idea what the gen 3 hemi weighs confused
Re: Early Hemi into an B-Body [Re: Stewpar] #2886935
02/11/21 09:31 PM
02/11/21 09:31 PM
Canada
demon Offline
demon  Offline
Canada
It fits. I had a friend put one in a 64 Polara [B body}. The motor mounts are easy. a 57-58 392 use the same mount ears as a 318. Small block mounts are a direct bolt on. An aluminum 727, or 833 4 speed bellhousing is a direct bolt on too, but, you need a spacer kit because the 392, like all 61 and earlier Mopar V8's, has a crank flange that sticks out further than a 62 and newer V8. Most of the early Hemi specialist shops sell these adapter kits.
Yes, an early Hemi is heavy, but if you use aluminum parts like intake, water piump etc, plus tube headers, it will be no heavier than a 440.
Width isn't an issue, if the engine is installed from above. The 57-58 392 is wider than a 426, but it does clear.
One of the main reasons the 426 was made narrower than the early Hemi's, was for assembly line installation. It had to be narrow enough to pass up, between the frame rails of a B body.
All Mopars of this era had the body dropped over the engine, so whether it was a 225 six or a 426 Hemi, the engine and trans was mounted to the assembled K frame, and the body dropped over top.
In fact, the 392 Hemi has a superior cylinder head design in several ways, compared to a 426 Hemi. The 392 has a virtually direct flow from intake through exhaust, where the 426 has some bends and bumps, necessitated by the intentional narrowing of the package, for assembly line ease.
As for performance, just look at all the records set in the 50's and 60's by 392's. These engines have incredible performance potential, so depending on budget, you can make it as fast as your wallet allows.
Re: Early Hemi into an B-Body [Re: demon] #2886945
02/11/21 09:44 PM
02/11/21 09:44 PM
n.c.
geo. Offline
geo.  Offline
n.c.
it is a wide engine, always wondered how width compares to the newish mustang DOHC v8s?
Imagine lifting the hood and seeing a Firepower 354, very cool!
Re: Early Hemi into an B-Body [Re: demon] #2886947
02/11/21 09:46 PM
02/11/21 09:46 PM
Guitar Jones Offline
I like the idea, something different. At the least he didn't ask about swapping an LS in it.
Re: Early Hemi into an B-Body [Re: Stewpar] #2886954
02/11/21 10:18 PM
02/11/21 10:18 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
saw a 70 cuda with one at the carlile mopar show !
Re: Early Hemi into an B-Body [Re: calrobb2000] #2887023
02/12/21 01:47 AM
02/12/21 01:47 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There's a thread in the Race section of one in what appears to be a '71 Charger. I just bumped it up.
Re: Early Hemi into an B-Body [Re: slantzilla] #2887100
02/12/21 10:47 AM
02/12/21 10:47 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I saw a '68 Super Bee clone with one in it - a local guy. It was well done but it looked odd and ugly in there. Keep in mind that those old hemis cost a forture to build to make any power - they were very low compression motors. Hell, it'll cost you $500 just for an adapter for a more current transmission! You'd be far further ahead to drop in a basically stock big block and dress it up if you're after eye candy. Price everything out before you toiuch a wrench to a bolt !!
Re: Early Hemi into an B-Body [Re: Stanton] #2887236
02/12/21 02:52 PM
02/12/21 02:52 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
If you want a cheap way to see those Hemi valve covers under the hood of your B body, a fairly stock early Hemi can accomplish that at a reasonable cost. But it's impractical if you are going for high performance. The Gen 2 Hemi is so superior to the early Hemi in so many ways. It's almost impossible not to make 700 horsepower with a nearly stock, naturally aspirated, stroker Gen 2 Hemi build. With an early Hemi, you will spend a lot of money, spend a lot of time chasing hard to get parts, and work really hard to get 700 horsepower.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Early Hemi into an B-Body [Re: Stewpar] #2887281
02/12/21 04:07 PM
02/12/21 04:07 PM
When my Son first move up to Bend, OR in 1992 there was a 1968 Charger with a 1957 New Yorker 392 C.I. Hemi motor in it, it looked like it was made that way, it was for sale but I don't remember the costs now. I was hoping it was a 426 hemi car but no such look whiney shruggy
I've own several different original 1957 and 1958 Chrysler and Imperial that had those motors in them stock including two Chrysler 300 car that came stock with solid lifters and in line dual quads, those 300 motors ran a lot better with a single four barrel dual plane intake off of a regular 392 with the stock 392 Carter WCFB four barrel drive ability wise on the street up The dual quad intake was a simple log type single plane intake manifold with progressive linkage on the
dual 4 barrel carbs. down
They ran and drove okay at light part throttle operations and better at WOT shruggy
Those cars were very heavy and handled like a big boat, not well at all down
Re: Early Hemi into an B-Body [Re: Cab_Burge] #2887334
02/12/21 05:11 PM
02/12/21 05:11 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
What's "hard to get" ??? Hot Heads carries anything you'd possibly need. http://hothemiheads.com/
Re: Early Hemi into an B-Body [Re: Stanton] #2887345
02/12/21 05:35 PM
02/12/21 05:35 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
perhaps it's better now, back in 20 15, getting a custom cam took a couple months, the missile rockers took over a month, finding someone with a program to CNC port the heads and get it done took months. Took over a year to find a 5/8 stroker crank. If you just order everything out of a catalog, I'm sure it would go quicker, but then it is unlikely that you will make 700 horse NA either.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Early Hemi into an B-Body [Re: Hemi_Joel] #2887388
02/12/21 07:37 PM
02/12/21 07:37 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
well why do you need over 700 hp ? why ot make that limit min 1500 hp ?
i built a trans for a guy that has one that has 600 hp in a 55 dodge .
street driven ! nice car !
Re: Early Hemi into an B-Body [Re: Hemi_Joel] #2887412
02/12/21 08:44 PM
02/12/21 08:44 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
Well who said anything about 700 HP ... other than you ?!?! The OP was just about the feasibility of the installation.
Re: Early Hemi into an B-Body [Re: Hemi_Joel] #2887962
02/14/21 08:39 AM
02/14/21 08:39 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not even sure how where you get your parts makes a difference to the build. Not like the Mad Scientist of Mopars has a stash of makes more than 700hp NA goodies in the Cave of Doom only available only to supplicants that arrive upon mule back to receive the imparted wisdom.
